minnesotamatt
Joined: 02 Dec 2009 Posts: 16 Location: woodbury minnesota
Posted: Mon May 10, 2010 1:41 am Post subject: ELECTRICAL PROBLEM help?? |
Ok so i just replaced my battery recently because everytime i turn off the engine and just leave the radio on and then try to start it after only a few min it wont start. just gives all the simtums of a dead battery so i then would have to jump it and it ran fine. However, after i replaced the battery i tried it again only it was worse. I went to start it and NOTHING came on, not even the dome light, when i went to put the key in normally the radio turns on but NOTHING came on. Any idea what the problem is?
Please help !
Thanks |
TJC
Joined: 04 Apr 2010 Posts: 828 Location: Northwestern-ish Arizona, USA
Posted: Mon May 10, 2010 3:34 am Post subject: |
I'd start with body grounds and connections to starter, make sure everything is tight and clean.
There's a thread in here about the body ground locations so you may try a search. _________________ '95 BMW 318i/5 ..."Pearl"
'04 BMW X3..."Xander"
Still on the Prowl!
www.ttrs1.com |
minnesotamatt
Posted: Mon May 10, 2010 11:10 am Post subject: |
| Ok i will thanks! |
