Possessed Headlights
Eska
PostPosted: Tue May 11, 2010 11:45 am    Post subject: Possessed Headlights Reply with quote
Hello again, after a few rough weeks at work I was finally able to spend some quality time with my new 924. (Pics coming soon) I've recently come across a very annoying quirk in my headlights, and any input would be greatly appreciated.
Occasionally when I turn them on, they raise all the way up, then drop about 3 inches. After a few "off and on" battles, it will stay up where they are supposed to be. Other times I turn them on and they continually move up and down rapidly until I remove the key.
Fuses are okay, and I followed as much of the wiring I could, that seems okay. I thought about adjusting the lights themselves, but didn't want to blind everyone around me when they do sit at the right spot. Any suggestions?
1988 "Please Pull Me Over" Red 924
1995 Dodge Ram 1500 with 6'' Lift - For hauling all my friends junk around and rainy days.
968rz
PostPosted: Tue May 11, 2010 1:53 pm    Post subject: Reply with quote
Check the relay, it's mounted to the passenger side motor under the rubber cover.
Rick
79 924 coupe Petrol Blue 3spd auto (wife's DD)
93 968 coupe Amazon Green 4spd Tip (my DD)
staticsan
PostPosted: Tue May 11, 2010 5:14 pm    Post subject: Reply with quote
I had a similar but lesser problem.
Easy bit: Check the plug and socket on the raising motor. Check it's not loose and that all the pins are securely mounted in the plug. And also that the relay is secure in the socket.
Harder bit: pull the motor and clean the switching disc. This is easier than it sounds.
1. Leaving the lights down, unplug the socket on the raising motor.
2. Unbolt it from its bracket and from the raising arm.
3. Pull the rubber boots off. The big one over the gearbox is going to seem impossible, but it stretches more than you would think. Just don't tear it.
4. Now you can pull cover off. Carefully: you don't want anything to fall out.
5. The disc will accumulate grease over time, which is great for lubrication but terrible for conduction. Clean the grease off the tracks and the contacts. Don't turn the disc if you can help it, but it's not that important if you do.
6. Put it all back together.
I found that if you do turn the gear box at all, then the second-last thing you do is plug the socket back in and the last thing you do is put the bolt back in to the raising bar. This lets the motor reset it's position to where it thinks is fully lowered before you bolt the raising bar back on.
I don't have pics, sorry.
Wade.
PostPosted: Tue May 11, 2010 5:34 pm    Post subject: Reply with quote
I have had problems to, they were all solved by changing the headligth switch. The same solution for a friend of mine which also had popup problems on his 924.
Eska
PostPosted: Fri May 14, 2010 2:15 am    Post subject: Reply with quote
Thanks for all the input. I have today off so hopefully I can pinpoint where the issue is. Thanks again
secretsquirrel
PostPosted: Mon May 24, 2010 6:24 am    Post subject: Dodgy lights.... Reply with quote
I know its no help to your problem...
But years ago, I had a Lotus Elite 501, (yeah the rep for Loads Of Trouble Usually Serious is true !)
During a slow crawl to work one day, Nearside light pops up, flashes, goes down, followed by Offside light, pops up, flashes, goes down...repeatedly for a couple of miles. At which stage, woman in car in front, gets out, comes to my car, hammers on hood, then drivers window, and screams at me accusing me of harrasment...
[/b]
'83 924, absolutely straight, original, low miles...just another sad bloke with a fatal, expensive, addiction to old cars....the list is long and boring !
