Oil cooler from 944 S2 in 924 S?
Browar
PostPosted: Sat Mar 06, 2010 5:06 am    Post subject: Oil cooler from 944 S2 in 924 S? Reply with quote
Hello,
Anybody done that?
I wonder how You routed oil cooler lines - they are too long...
And how You mounted cooler - pic needed!
Browar
eS
924 S `87
bcblase
PostPosted: Tue Mar 23, 2010 5:59 am    Post subject: Reply with quote
You might want to consider an aftermarket solution - they are designed for the 944 NA engine, and should be an easy kit to install.
www.lindseyracing.com
1987 Porsche 924S - track toy
2001 BMW 325xi - daily driver
ic932
PostPosted: Tue Mar 23, 2010 6:58 am    Post subject: Reply with quote
The 89' S2 oil cooler is the one to go for. Its a little larger then the 931 cooler and fits in the same place. As I have my front spolier off at the moment I'll snap a pic for future reference.
Autually after looking at the 931 and 89' S2 cooler side by side, the S2 is considerably larger.
Well exceeding what you will ever need on an 924S I would imagine.
PostPosted: Tue Mar 23, 2010 8:03 am    Post subject: Reply with quote
Grab a salvage 951 filter console, and you can run whatever cooler you want. Best solution is an aftermarket unit in mounted front of the rad.
ic932
PostPosted: Wed Mar 24, 2010 2:20 am    Post subject: Reply with quote
Hers some pics of how the 944S2 (89') oil cooler is fitted. Also note the comparrison between the S2 and 931 cooler. Also pictured is the oil distributer head that Rasta mentioned.
Seems to me this is a bolt on upgrade for 924S.
PostPosted: Wed Mar 24, 2010 4:12 pm    Post subject: Reply with quote
Not sure that unit (as mounted in the pic) would fit behind a toofah valence.
ic932
PostPosted: Thu Mar 25, 2010 1:12 am    Post subject: Reply with quote
Yeah I think you are probably right. An opening would have to be cut in the valence.
PostPosted: Thu Mar 25, 2010 1:23 am    Post subject: Reply with quote
<lights cutting torch>You want what, where?
ic932
PostPosted: Thu Mar 25, 2010 1:33 am    Post subject: Reply with quote
What do you mean? The lights are all in the bumper. The cooler sits well below the bumper line.
PostPosted: Thu Mar 25, 2010 1:49 am    Post subject: Reply with quote
Sorry, forgot the smiley face.
ITS A JOKE!
ic932
PostPosted: Thu Mar 25, 2010 2:00 am    Post subject: Reply with quote
Ahhh gotcha now... as in - lights, camera, action...you want what, where?
Humour bypass on my part, sorry.
Browar
PostPosted: Sun Mar 28, 2010 10:05 pm    Post subject: Reply with quote
Wow! Great pictures!. That`s something I was looking for. I made instalation with 944S2 parts. Oil pipes needs to be shorten -> it is impossible to fit cooler and power steering cooler lines in front valance. Also cars with power steering has issues with power steering pump belt and puley (very small room in that area). At the moment everything is fine.
Once again thank You for input and sharing.
Browar
eS
924 S `87
ic932
PostPosted: Mon Mar 29, 2010 7:40 am    Post subject: Reply with quote
Yeah, most in fact all 924S (that I have seen) have power steering. Its a compact system with NO extra consideration for the 924S. it sits well within the 924 skinny body.
Since you are still modifying oil cooler pipe length, i'm guessing you are tyring to move the cooler back a few inches to stock 931 locations? (I'm presuming you are going with 89' specific cooler?). Space is tight lol.
Next time you post, picture what you are doing, and be prescise with model year ect..the 89' is a one year only application.
bcblase
PostPosted: Sat May 01, 2010 12:29 am    Post subject: Reply with quote
Here's the oil cooler from a 951 (944 turbo).
I am thinking of mounting this behind the right side of the front valence of my 924S.
I have already removed the power steering pump and other associated lines.
What do I need to attach the lines to the engine block? I assume the built-in 924S
oil cooler has to come off the engine block, and another housing (filter console)
that will accept the lines needs to be installed.
Anybody got pics of the engine side of the oil lines?
ic932
PostPosted: Sat May 01, 2010 12:45 am    Post subject: Reply with quote
