o2 sensor heat shield question
nivekrs
PostPosted: Wed May 05, 2010 3:50 pm    Post subject: o2 sensor heat shield question Reply with quote
I just replaced the o2 sensor on my '82na with a new Bosch sensor which was supposed to work on my '82 924 as well as 911,928,944 and found after I installed it that it was too big for my old o2 sensor heat shield to fit over. Is this a problem if I eliminate it? (The sensor heat shield) I don't want the new sensor to fail early because of this. Thanks for any advice.
Martijnus
PostPosted: Wed May 05, 2010 11:28 pm    Post subject: Reply with quote
I'm not familiar with the 924 heat shield itself, but you can make a heat shield yourself from aluminium.
I believe I found a pic on the megasquirt site, but I can't find it
924 "50-jahre", 1981.
MSII/extra, LPG, ITB's, 5lug.
To be turbo'ed in a while.
