Odometer Repair.
Goto page 1, 2, 3, 4  Next
PostPosted: Wed Apr 06, 2005 7:32 am    Post subject: Odometer Repair. Reply with quote
Decided to do several things at once.
I wanted two turn signals on the dash and not one so I removed the cluster.
While I was at it I had a go at fixing the odometer.
FWIW - it is not as daunting a task as one imagines.
With the cluster out it was a breeze to remove the speedo and then I followed the instructions in the FAQ.
I noticed the shaft the wheel is on, had a lot of play so I put some small spacers on it and behind the wheel to prevent this movement.
put it back together, tested it with a drill and one problem solved.
The other mod? I had 2 high beam dash lights. I removed the one above the speedo RH and installed the RH green light here. I installed the LH opposite side of the speedo and rewired back to the turn switch.
The other green light on the dash only works with the hazards.
PostPosted: Wed Apr 06, 2005 10:00 am    Post subject: Reply with quote
A pic can be seen here of the lights.
http://au.pg.photos.yahoo.com/ph/jaynar56/detail?.dir=b502&.dnm=2b9c.jpg&.src=ph
EDIT- this link has stopped working, check the new link below.
PostPosted: Wed Apr 06, 2005 10:50 am    Post subject: Reply with quote
I had a look at your other pics. Car looks good
Them's some seriously black tinted windows you've got!
And it's an auto How do you find that? I've had my eye on an old '77 924 NA auto for a while now.
It's still sitting there at the shop, saw it last weekend on the way out to my parents place. When I get some spare cash I'll go bug the owner again
Gram
PostPosted: Wed Apr 06, 2005 11:08 am    Post subject: Reply with quote
Cool idea. I've always wondered why there were 2 main beam ind. lights..
Your car looks good BTW.
'82 924 NA Euro (hers)
'98 Audi A4 TDI (ours)
PostPosted: Wed Apr 06, 2005 2:54 pm    Post subject: Reply with quote
Thanks. Although the it came out ok in the pics the paint needs work.
The tint was on it and I think its called panther black.
Auto- just what I wanted and waited long enough I found it and bought it.
PostPosted: Fri Apr 08, 2005 7:29 am    Post subject: Reply with quote
I have a modified wiring diagram to show how I rewired the dash if anyone wants just pm or email.
PostPosted: Sat Apr 09, 2005 7:22 am    Post subject: Reply with quote
I can't see the pix ... the link says I have to log in ...
PostPosted: Sat Apr 09, 2005 7:28 am    Post subject: Reply with quote
Yahoo can be a pain. try this one
http://community.webshots.com/user/jaynar57
PostPosted: Sat Apr 09, 2005 7:35 am    Post subject: Reply with quote
same problem ... says I'm not the owner....
PostPosted: Sat Apr 09, 2005 7:52 am    Post subject: Reply with quote
If anyone can explain how to insert a pic into this thread?
this works
PostPosted: Sat Apr 09, 2005 8:46 am    Post subject: Reply with quote
Bring up the picture on Webshots or wherever you have it uploaded, do a right-click, select "properties" (if using IE), then select and copy the url address. That's -
http://image48.webshots.com/49/3/2/91/317630291pYZFlc_ph.jpg
(Many webspace sites change the filenames regularly, so we'll find out soon enough if Webshots does this. Others, like Yahoo don't allow direct linking to .jpg files)
Then to post the pic so it appears in the post, put (img) before and (/img) after the url (but replace those parens with brackets).
PostPosted: Sat Apr 09, 2005 8:52 am    Post subject: Reply with quote
Testing
http://image40.webshots.com/41/2/81/71/317628171qptLte_ph.jpg
Too easy
Well... it did work once.
PostPosted: Sat Apr 09, 2005 9:20 am    Post subject: Reply with quote
That's weird. They're not changing the filenames...
I'll remove the pic from my previous post and see if yours shows - maybe they somehow limit the number of pics that can be linked to.
PostPosted: Sat Apr 09, 2005 9:24 am    Post subject: Reply with quote
Well now yours is there and mine's gone and I didn't do anything yet. Very strange. Still maybe a limit on the amount of data they'll send at once. Try changing from full size to thumbnails.
Page 1 of 4
