Posted: Fri Mar 19, 2010 3:34 am Post subject: Group Buy (ACTIVE): Stage 8 locking CV bolts, Round 2 |
Back by popular demand!
We are pleased to announce that Stage8 has extended the 25% discount pricing with no minimums on the participant list! They were so stoked at the huge participation of the first round group buy (110 orders, not counting extras!!!) that they have extended the special group buy pricing to our second round, which will run from now through 15 April 2010.
Pricing
MSRP = $106 per set of 24 bolts, clips & retainers
Group Buy discount = 25% off MSRP
Group Buy Price = $79.50
Shipping*: US = $6; Canada = $12.45; ROW = $14.45
*Note: Shipping is via USPS priority mail small flat rate box. We can fit up to two full sets in one box; add'l quantities will result in slightly higher shipping costs.
Ordering
I have set up a special application guide and group buy ordering page on my website:
To order => http://garage.ideola.com/prod-Stage8-GB.html
Please order through this page if possible. Otherwise, send me a PM with the details of your order and I will invoice you via paypal.
Specifications
• Bolts Are Aircraft Quality Grade 12.9 – 4130 Alloy Steel
• Retainers are 5052-H32 Polished Aluminum
• Snap Rings & Clips Are Spring Steel
Background & Product Details
For those that missed the first round, here is a repeat of the details. I worked with Stage8 to develop a locking CV bolt kit for the entire range of 924-944-968 cars. After the first round, we now can offer applications for the entire range of 914, 911, and 928!
The 924-944-968 application utilize twenty-four M8x48 cheesehead bolts to attach the half shafts at the transaxle stub axles and the outer hubs (six bolts per CV joint). As many of you know, the cheese head bolts are a royal PITA to deal with and will strip out if you're not careful. And for track driven cars, there have been multiple reports of the bolts backing out mid-session with catastrophic results. Many guys are safety wiring their bolts, and this was the approach I was planning to take on my UWB project until a 924board member mentioned Stage8 (for a header bolt application).
The Stage8 system utilizes their patented "GrooveLok" bolt, which has a 12-point head and a special groove in the head. Once the fastener is torqued down, any number of clip shapes are available, which lock onto the 12-point bolt head, and are then retained using either an E-clip or snap ring. Here are some photos using the samples they sent to me installed on a late offset 944 CV joint, boot, and outer stub axle:
M8x65 GrooveLok bolt (the standard 924-944-968 size would be M8x50)
Teardrop and D-Style clips; snap ring and E-style retainers
D-style clips installed, E-style retainer on left, no retainer on the right (I didn't have a spring plier small enough at home)
Teardrop retainers installed (again, no spring clips, but they would normally have the spring clips installed)
Questions? Interest? Let me know! _________________ erstwhile owner of just about every 924 variant ever made |
Rocco R16V
Posted: Fri Mar 19, 2010 10:07 am Post subject: |
These work with almost all VW and Audi cars built before ~'97 and lots after.
*please verify application before buying, by finding the spec of your car or carefully measuring. Seller has not made any promises of fitment other than stated by him. _________________ "Government exists to protect us from each other. Where government has gone beyond its limits is in deciding to protect us from ourselves. "
Ronald Reagan |
Posted: Fri Mar 19, 2010 10:58 am Post subject: |
Thanks Rocco  _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Sun Mar 21, 2010 2:13 am Post subject: |
Answers to a few questions that have come in:
Q: Are the bolts re-usable?
A: YES, absolutely. They are made of 12.9 grade steel.
Q: Looks like I need a special tool to install these?
A: NO, all that is required is a standard 12-point 8mm or 10mm socket. It is highly recommended to use a high-quality socket, as some of the el-cheapos don't provide good engagement at the opening of the socket. Standard snap ring pliers are all that's required for the retainers.
Q: I see that Stage8 provides E-style retainers, and those seem easier to install. Can I order them?
A: Stage8 strongly recommends the use of snap rings for moving applications such as CV joints due to the full circle engagement, even though the risk of losing an E-style retainer is very small.
Q: Are the E-style retainers interchangeable with the snap rings?
A: NO, the E-style retainers require a wider groove in the GrooveLok bolt, so the bolts must be machined differently.
Q: I see that Stage8 offers Teardrop style retainers. Can I order them?
A: SORT OF(!). For the group buy, I am limiting the bolt configuration to D-style clips and snap ring retainers to help simplify the ordering, production, and fulfillment process. However, if you really want some teardrop style retainers, at the bottom of the Application Guide page, you may order 6-paks of extra clips in either the D- or Teardrop shape ($3 per pak less 25%)
Q: I'm worried about losing a bolt or retainer set. How do I get more if I lose one?
A: At the bottom of the Application Guide page, you may order 6-paks of extra bolts ($26 less 25% per 6-count), clips ($3 less 25% per 6-count), and retainers ($3 less 25% per 6-count) _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Wed Mar 24, 2010 8:26 pm Post subject: |
I received the 20th order last night, so I will be placing the first batch order with Stage8 later this afternoon. Anyone wishing to be included in the first batch order, please get your orders in before 5 PM EDT today. _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Mon Apr 12, 2010 10:25 pm Post subject: |
UPDATE:
Spoke with Stage8 on Friday. Batch 1 may ship to me by the end of this week, Batch 2 probably not until the end of next week at the soonest.
There's still time to get in on this...original closing date was thru Tax Day...we'll go ahead and extend it thru the weekend: Sunday 18 Apr 2010. _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Fri Apr 16, 2010 11:04 pm Post subject: |
72 hours left in the group buy. Batch 3 orders will be placed with Stage8 on Monday, so please get your orders in no later than 11 AM EDT Monday 19 April. _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Thu Apr 29, 2010 4:40 am Post subject: |
I sent this email to everybody today, but posting here just to cover all the bases...
I spoke with Stage8 last night regarding the status of shipping on the various batch orders. For some reason, they delayed shipping batch 1 and pulled forward the production run of the batch 2 and batch 3 orders. They committed to me that the entire order (batches 1, 2 & 3) will be shipped to me all at once by the end of this week.
I don't know why they did it this way, as I specifically discussed with them at the outset breaking the orders into smaller batches so that early participants wouldn't have to wait for the entire run in order to get their parts. They arbitrarily decided to do the production all at once, which means that those of you in Batch 1 won't be getting your orders any sooner than anybody else.
I'm not real happy about this, and will have to think about how to manage the next round (if there is one). BUT, the good news is that everything should be on its way from California by the end of the week, and I should be able to begin packaging and shipping next week. I will do my best to get everything repackaged and shipped out to you all within 24-48 hours of receiving the bulk shipment from Stage8.
I apologize for the delay, I wish there was something I could do to get the parts here faster. The only consolation I can offer at this point is that it's not unusual to encounter these types of production and logistical issues when commissioning a completely new product (there were 5 new applications in this round of the group buy). I hope you feel as I do that the results will be worth the wait.
Once I start shipping your individual orders, you should each be getting an email notification from either PayPal or the USPS with the tracking number for your shipment, so please be on the lookout for that. I think I have requested address confirmations from all of you, but it doesn't hurt to remind you that I rely heavily on your PayPal address being correct for shipping. PLEASE double check that your PayPal shipping info is current and up to date!!!
I will send out another update as soon as I know the bulk shipment is on its way from California. In the meantime, if you have any questions or concerns, please let me know. Thanks again for your enthusiastic participation! It has been exciting to see the response to this group buy. If there are other new product or NLA parts you would like assistance with, don't hesitate to ask...I'm always up for a new challenge!
Also just a quick reminder that we're offering 10% off all Tools, Kingsborne Wire Sets, and Classic 9 appearance products through 15 May 2010. _________________ erstwhile owner of just about every 924 variant ever made |
macBdog
Posted: Thu Apr 29, 2010 1:15 pm Post subject: |
Just ordered and paid, PayPal shipping address is correct. They come with the retainers and clips right? _________________ 1979 931 with a 350 chev
1973 911E with EFI
Posted: Thu Apr 29, 2010 1:19 pm Post subject: |
| macBdog wrote: | | Just ordered and paid, PayPal shipping address is correct. They come with the retainers and clips right? |
Yessir! _________________ erstwhile owner of just about every 924 variant ever made |
