Posted: Mon Aug 16, 2004 2:39 pm Post subject: Lowered front end.... |
Im waiting on my lowered 250lb springs. This last friday im on the freeway
thinking its time to redo my valance though Id like to have the front lower too. I know Ill try and do both lower the car and rebuild the valance though that would be pretty tough got to be done by sunday early as I get up early monday. Plus I left the steel Im gonna use ar work I didnt even measure the lengths Ill need. Yesterday I go by autozone and rent there spring compressors and go home to give the stock springs a cut. I stopped at Knects autoparts and get a couple 3"cut-off wheels the ones from harbor freight are shit they dont last... This is the stock height its to high.
After I it was lowered.
To be safe I should have a 1" length if pipe the same dia as the upper sring perch welded to it to house the spring better its in there solid and all.
Handles just about the same though a little different as its lower seems stiffer too as spring rate has shall I say changed. These are the 944 springs I cut up.
It still handles like a porsche. _________________ 1979 porsche 924 Na
Have u ever driven a turbo. |
Posted: Mon Aug 16, 2004 3:23 pm Post subject: |
still working on the GF car eh Joe, so when are you going to get your own? _________________ 3 928s, |
Neil924
Posted: Mon Aug 16, 2004 11:41 pm Post subject: |
| Geeze Joe, you're always doin' somthin' to it! It still looks good. |
924 turbo
Posted: Tue Aug 17, 2004 2:49 pm Post subject: |
Looks good, Joe! _________________ Jon Furst |
Posted: Tue Aug 17, 2004 3:27 pm Post subject: |
See how lower it is its great ..anyway I drove home from work
in the dark (an hour long freeway ride... And its alright its time to
put the the front belly pan back on does that thing help with the
airodynamics and the air flow...Im thinken the air gets wipped up under the fenders and other parts and acts as wind shear. _________________ 1979 porsche 924 Na
AndyFranklin
Posted: Tue Aug 17, 2004 11:12 pm Post subject: |
| The belly pan should prevent lift. |
Diesel
Posted: Wed Aug 18, 2004 7:59 am Post subject: |
| Who's the girl washing the car in the backround? |
Posted: Thu Aug 19, 2004 3:25 pm Post subject: |
Prevent lift ...and less drag maybe 'yea I have to get that one
ASAP I think ...the girl washing the lexas ... O shes the owner of the 79 924
like Lizard said ... .. . my girlfriend.
What does this look like to you guys: ... .. . just that 3 dots then 2 and one. like this ... .. . reminds me of the spaceshuttle discovery breaking up on rentry. _________________ 1979 porsche 924 Na
J1NX3D
Joined: 06 Feb 2003 Posts: 1333 Location: New Zealand
Posted: Thu Aug 19, 2004 5:57 pm Post subject: |
| AndyFranklin wrote: | | The belly pan should prevent lift. |
is the 924 n/a and 931 belly pan the same? _________________ '86 944 |
Posted: Sun Aug 22, 2004 2:58 pm Post subject: |
So its time to tell and heres gos you know the freeway system in portland oregon isnt the greatest and theres a few spots where if Im haulen ass
say like 75mph in this one curve or down a hillside doin the same well the tires and fender lip make contact a little ..this is a bad thing. So it makes for a drive planned to go slow in the bad spots such as bridges. I drive pretty fast sometimes Ill be damned if I can explain. Only when the time is right do I go fast though.. _________________ 1979 porsche 924 Na
Llamaguy
Posted: Mon Aug 23, 2004 1:22 am Post subject: Re: Lowered front end.... |
what happened to the lower panel? I have the same damage on my car _________________ 1987 924S Guards Red
1997 Suzuki Tl1000 Supersport |
PORSCHEV
Posted: Thu Aug 26, 2004 9:42 am Post subject: |
Whats the deal Joe??? I have read these digs from time to time that the car is your girlfriends car?? Is this an inside joke I am missing? or is that really your girlfriends car? And if it is..why do you always drive it and build it as you want?? _________________ 1976 924
1978-#53 "D" track racer. |
Posted: Thu Aug 26, 2004 9:45 am Post subject: |
nope you got it right, it is his gf car, and Joe man learn where to place the jack man, you crumpled the bottom side of that fender. _________________ 3 928s, |
Posted: Fri Aug 27, 2004 4:09 am Post subject: |
Ok, tell me your secret..., How do I get a GF with a porsche  |
Posted: Fri Aug 27, 2004 11:23 am Post subject: |
Hang out at golf courses. Check out the owners of the golf course
and see if you can find out if they got any cute chicks for as in there offspring ..take it from there a porsche will find its way into the picture
for you too soon enough maybe. Its a mind set thing and you cant have any other thoughts it demands complete concentration and takes up all of your time. _________________ 1979 porsche 924 Na
