1980 WEATHER STRIPPING
POOCH
PostPosted: Tue Apr 27, 2010 3:14 pm    Post subject: 1980 WEATHER STRIPPING Reply with quote
Am i really left with ordering drivers side door rubber for $75.00 and up. Does anyone have an alternative to this gouge?
PostPosted: Tue Apr 27, 2010 8:48 pm    Post subject: Reply with quote
How does used fit in to your needs? May have what ya need.
PostPosted: Tue Apr 27, 2010 10:59 pm    Post subject: Reply with quote
Used should be a great option, especially if you can find a set from a 924S, as they have a slightly upgraded design and a much more positive seal around the door frame. A little bit of GooGone and Mother's Back to Black (applied in that order) will do an amazing job of dressing up old seals. I just went through this process on the 941. I still need to apply some adhesive, but just haven't gotten around to it yet.
POOCH
PostPosted: Tue Apr 27, 2010 11:27 pm    Post subject: Reply with quote
Ok used it is since I'm not planning on replacine the passenger side maybe used is the best option. I've got a 931 but I don't imagine model would matter regarding door rubber. Grenadiers let me know what you're thinking $$
PostPosted: Tue Apr 27, 2010 11:38 pm    Post subject: Reply with quote
The door rubber is all pretty much interchangeable...I was just point out that the 924S has an improved design over the earlier seals, with the added benefit that the seals will be at least 5 years newer than the newest 924/931, and much more likely to be in good condition. But you can still use seals from essentially any 924/931/924S/944.
Scorpio
PostPosted: Wed Apr 28, 2010 1:09 am    Post subject: Reply with quote
same problem...might take my old seals into clark Rubber to see what they have...does the 928 have the same cross sectional rubber shape?
1979 NA
MS1..EFI..
GARRETT T25 TURBO
BILSTEIN SHOCKS
GT BASED CUSTOM BODYKIT
Brisbane , Australia
Think mean think fast
all youll see is
my Porsches Arse!!!
