rear leak problem still!
ZODIAC
PostPosted: Thu Apr 08, 2010 10:00 am    Post subject: rear leak problem still! Reply with quote
okay, i thought that i had solved the problem by relaceing the rubber buffers (hatch latching seals) that are set into the body, i even siliconed a little to help. but i am still getting water that runs down the back of the taillights. is there another gasket or seal that is supposed to be around the latch studs on the hatch? maybe the rubber fuel hoses that i have as drainage tubes arent flowing enough and backing up causeing the leak?
i need to solve this so i can at least finish stripping rust and sort out my brake light issues. this is the only area where i havent been able to sort out a leak, therefore the only non-water tight area.
"Kraut cars, they know how to build 'em".
1977 924 N/A - Red with waterdamage interior
yes...waterdamage is now a color...
Rich H
PostPosted: Thu Apr 08, 2010 5:49 pm    Post subject: Reply with quote
Are your light cluster seals OK? They go crusty and leak
PostPosted: Fri Apr 09, 2010 2:58 am    Post subject: Reply with quote
Inside the tail ights.??
ZODIAC
PostPosted: Fri Apr 09, 2010 10:45 am    Post subject: Reply with quote
this is an excellent idea, i hadnt thought about that before. please dont tell me the seals are NLA!
mikebola
PostPosted: Fri Apr 09, 2010 11:04 am    Post subject: Reply with quote
I just used something from 3M called "Strip Calk"
it works great for light seals.
proud owner of a 1979 924 Sebring Edition with a 931 trans that looks horrible but somehow runs...
