dash16
Posted: Mon Apr 12, 2010 6:18 pm Post subject: how do I remove the stock tri-spoke steering wheel? |
can't find anything on it. thanks _________________ 1987 Porsche 924S Black/Black. 5-spd.
Options: AFX C79 261 398 423 650 651 657
1987 Mercedes 190E 2.3-16 Cosworth Pearl Black/Black. 5-spd.
STUTTGART PREVAILS |
Rich H
Posted: Mon Apr 12, 2010 6:26 pm Post subject: |
get hold of the horn pad and yank it off. It clips on in 3 places.
There is a 22mm nut in the centre then. But mark the wheel and shaft for re-alignment it's tricky toi get right!! _________________ 1994 Lotus Esprit S4 - Work in progress...
dash16
Posted: Mon Apr 12, 2010 6:52 pm Post subject: |
will I risk breaking something if I yank the horn pad out? _________________ 1987 Porsche 924S Black/Black. 5-spd.
Rich H
Posted: Mon Apr 12, 2010 6:56 pm Post subject: |
yes, welcome to 30 year old cars
It's the only way and they are sometimes very hard to remove. They are normally fine though and can take the rough handling. Mine has been apart loads of times withotu incident. You can normally pop off one at a time, just pull the end of each spoke by hand. I wouldn't try and lever it off.
If you break something the clips on the steering wheel side can be replaced. _________________ 1994 Lotus Esprit S4 - Work in progress...
Posted: Mon Apr 12, 2010 10:58 pm Post subject: |
| dash16 wrote: | | will I risk breaking something if I yank the horn pad out? |
Yes, your nose!
Seriously, it requires some force to remove, and you could easily bash your nose in if you're not prepared for the release when it finally lets go... _________________ erstwhile owner of just about every 924 variant ever made |
paulsmaroon924
Posted: Tue Apr 13, 2010 7:27 pm Post subject: |
yeah be careful, first time i did it about 6 years ago i had a screwdriver in my hand and i nearly tore my own eye out!!
its wonderful how hindsight is always perfect 20/20 vision |
