engine timing
IROCZ
PostPosted: Sat Jun 19, 2010 11:38 am    Post subject: engine timing Reply with quote
as l put in timing my car porsche 924 turbo 1981 sorry my english
924 TURBO 1981
Scorpio
PostPosted: Sat Jun 19, 2010 11:58 am    Post subject: Reply with quote
1979 NA
MS1..EFI..
GARRETT T25 TURBO
BILSTEIN SHOCKS
GT BASED CUSTOM BODYKIT
Brisbane , Australia
Think mean think fast
all youll see is
my Porsches Arse!!!
968rz
PostPosted: Sat Jun 19, 2010 12:34 pm    Post subject: Reply with quote
Eso es difícil de entender.
Probar este traductor.
http://translate.google.com
Rick
PostPosted: Sat Jun 19, 2010 8:50 pm    Post subject: Reply with quote
Maybe you put too much timing in...?
Nein37
PostPosted: Sun Jun 20, 2010 1:41 am    Post subject: Reply with quote
Timing is not adjustable on 1981 924 turbos. Its controlled by the DITC unit.
Martijnus
PostPosted: Sun Jun 20, 2010 6:25 am    Post subject: Reply with quote
I thought the DITC only controlled the ignition timing... but apparently also the cam timing?
I'll explain in short how to time the cam:
on your marks
get set
GO!
924 "50-jahre", 1981.
MSII/extra, LPG, ITB's, 5lug.
To be turbo'ed in a while.
PostPosted: Sun Jun 20, 2010 8:13 am    Post subject: Reply with quote
Give the guy a break.
PostPosted: Sun Jun 20, 2010 9:44 pm    Post subject: Reply with quote
Si puede explicar la problema en espanol, es posible que yo podere traducir a ingles.
Mike
Martijnus
PostPosted: Mon Jun 21, 2010 12:32 am    Post subject: Reply with quote
I don't speak spanish, but I can understand this perfectly
