Carrera GT rear fenders, how to fit them ?
Goto page 1, 2, 3  Next
Dutch924-racer
PostPosted: Wed Sep 30, 2009 3:28 am    Post subject: Carrera GT rear fenders, how to fit them ? Reply with quote
I have bought a set of Carrera GT (replica) rear fenders.
How do you mount them ?
Has anybody got pictures of the inside of the fenders?
937 trackday car
Series 2 engine
951S turbo and intercooler
Fast road camshaft
gegge
PostPosted: Wed Sep 30, 2009 4:49 am    Post subject: Reply with quote
My steel fenders are cut and folded. The GT fenders are fixed by ten M10 screws moulded in the fiberglass.
Carl Fredrik Torkildsen
Dutch924-racer
PostPosted: Wed Sep 30, 2009 5:08 am    Post subject: Reply with quote
So I have to drill hols in them and cover it with filler ?
937 trackday car
Series 2 engine
Fast road camshaft
Dutch924-racer
PostPosted: Wed Sep 30, 2009 5:20 am    Post subject: Reply with quote
I have found some pictures looks like they are mounted with pop-rivet
937 trackday car
Series 2 engine
Fast road camshaft
Maybe924
PostPosted: Wed Sep 30, 2009 7:13 am    Post subject: Reply with quote
The silver car is my 931 project. I mocked the fenders up making sure their position was correct, then drilled 6 holes all in places that could be accessed. Then I removed them and drilled larger holes in the outer skin so the bolt heads would fit through. I then placed bolts through to the lip of the CGT flare. After again attached them to the 931 body and applied a small amount of epoxy around the head of the bolts so they would bond with the lip. Once the epoxy on the bolts set I removed the flares and reenforced the epoxied bolts in place. I then fiberglassed the outer holes closed, did some finishing work, painted and reattached. Now the CGT flares can be removed as needed and are very securely attached.
1981 931 GT (CGT Intercooled)
1985 911 Targa Carrera (Sold)
v8carreragts
PostPosted: Wed Sep 30, 2009 2:25 pm    Post subject: Reply with quote
I will be using screws on the flanges and using 3M 08115 Automix Panel Bonding Adhesive.
Dutch924-racer
PostPosted: Wed Sep 30, 2009 4:36 pm    Post subject: Reply with quote
Thanks, great looking car !!!
I saw some people use liner (piping) between the body and the rear fenders.
937 trackday car
Series 2 engine
Fast road camshaft
ndrk
PostPosted: Wed Sep 30, 2009 7:04 pm    Post subject: Reply with quote
I think it looks much cooler and badass when rivets are showing...
Porsche 944R Nr4 of 9
Vince Ponz
PostPosted: Wed Sep 30, 2009 11:48 pm    Post subject: Reply with quote
A little history of my replica can be found on the topic
Going GT dated Oct 19 by MYCar
In it you will see where I cut the fenders and bolted the rears. You will see closeups of the bumpers, fenders etc. No that is not me painting the car.
77.5 924 modified track car
79 931 Euro stock
88 924S SE
87 911 Targa stock
flosho
PostPosted: Thu Oct 01, 2009 6:16 am    Post subject: Reply with quote
That'll be the style I will do, 10-12 bolts that will be fiberglassed into the rear flare and then have it be secured against the car.
I also plan to cut out that shape on the rocker panel to access the torsion bar; excellent idea there.
[This Space For Rent]
v8carreragts
PostPosted: Thu Oct 01, 2009 10:16 am    Post subject: Reply with quote
I can't find this. Searching comes back with nothing.
Dutch924-racer
PostPosted: Thu Oct 01, 2009 4:28 pm    Post subject: Reply with quote
http://www.924board.org/viewtopic.php?t=27341&highlight=fenders
937 trackday car
Series 2 engine
Fast road camshaft
Dutch924-racer
PostPosted: Thu Oct 01, 2009 4:30 pm    Post subject: Reply with quote
What kind of rear bumper did you use ?
937 trackday car
Series 2 engine
Fast road camshaft
Vince Ponz
PostPosted: Thu Oct 01, 2009 10:04 pm    Post subject: Reply with quote
You can use either the US bumper or the Euro bumper. I removed the rubber and filled in the holes. For the US guys/Girls you can cut the shocks, push in and weld to get the close look.
79 931 Euro stock
88 924S SE
87 911 Targa stock
PostPosted: Fri Oct 02, 2009 12:51 am    Post subject: Reply with quote
But Vince, using the US bumper and collapsing the shocks still leaves a gap between the bumper and the rear fender, which is normally covered by that funky rubber part. It doesn't look right on a collapsed bumper, but the bumper won't take up all of the gap either. The bumper in the photo above does not look like a US bumper...how were the ends extended to meet up with the rear of the fender?
Page 1 of 3
