Removing injectors and rubber parts
9xx
PostPosted: Thu Mar 25, 2010 1:31 am    Post subject: Removing injectors and rubber parts Reply with quote
I have removed CIS injectors from the engine. There are four rubber thingys that are still in the cylinder head, what do you call them, injector seats?.
How can I remove them? I noticed that two of them are turning around very easily and two of them are more firmly attached. Can I just pull them out using force? I'd like to replace them too. Thanks for your answers in advance.
Mikko
PostPosted: Thu Mar 25, 2010 1:37 am    Post subject: Reply with quote
Assuming they are the same as in my car, they are threaded and can be removed with a socket. I bought new ones from PCNA, and it appears they have been updated. . .will post pics here later.
9xx
PostPosted: Thu Mar 25, 2010 1:46 am    Post subject: Reply with quote
Yes there is metal peace attached to these rubbers, looking like a nut. Excuse my english. I'll try to turn them with a socket.
Mikko
9xx
PostPosted: Thu Mar 25, 2010 1:54 am    Post subject: Reply with quote
According to PET is "931 110 226 01 socket". Ok, I'll try using a socket.
Mikko
PostPosted: Thu Mar 25, 2010 3:00 am    Post subject: Reply with quote
The metal bits are also threaded into the plastic seat, so you will likely remove those and leave the seat behind. The black seat itself also should have a hex moulded into it. . .I wanna say a 14mm?
PostPosted: Thu Mar 25, 2010 3:47 am    Post subject: Reply with quote
Yes, I'm pretty sure...I was going to post that I had removed them by double nutting a bolt and using the bolt head to back out the plastic part, but I couldn't remember if it was on the 931 or the NA that I did this. 14mm seems right.
Just be careful when removing the plastic. If the PO used any kind of thread sealant, they can stick and be difficult to remove. You certainly don't want to break the plastic bit with the head in situ, so care is warranted.
