Starter motor problem....
nane
PostPosted: Thu Feb 25, 2010 2:42 am    Post subject: Starter motor problem.... Reply with quote
Hi everyone!!
I have change my engine (porsche 931 - 1980), and now, i dont know how to re-connect the wires from the starter motor. I have four... black... red... red/black and black/yellow. where should i connect each one?...
Thanks in advance...
Nane
PostPosted: Thu Feb 25, 2010 7:42 pm    Post subject: Reply with quote
The big red one goes to the large post (#30).
Small black to #15a (may be designated as #16 on some solenoids).
Small red/black to #50.
Not aware of any yellow/black wire to the starter. Leave it disconnected and insulated until you find out what it is.
Stuff like this is in the wiring diagrams, and stuff like wiring diagrams are in the rear of the Haynes manual, Porsche service manuals, and pelicanparts.com website.
nane
PostPosted: Thu Feb 25, 2010 11:33 pm    Post subject: Reply with quote
Thanks Smoothie... but... wich are the 30,15 and 50 conections in the starter motor?
[/img]
PostPosted: Fri Feb 26, 2010 1:39 am    Post subject: Reply with quote
You should be able to see the numbers on the solenoid. In this pic you can see the "15a" - but the starter is upside-down in the pic, so when it's installed, 15a will be at the bottom, 50 will be at the top, and 30 is the large one shown with no wire attached.. (Shown is a Bosch solenoid from a Jeep Cherokee that has spade terminals - obviously the 924 solenoid will have stud&nut terminals.)
nane
PostPosted: Fri Mar 05, 2010 7:19 am    Post subject: Reply with quote
THank you very much Smoothie... I GOT IT!!!!!!!
