auto 924s fuel starvation
switz60
PostPosted: Sun Feb 21, 2010 8:54 pm    Post subject: auto 924s fuel starvation Reply with quote
hi
im new to the forum but was hoping someone can help.I have an automatic 924s that was running fine then left for 8months it now runs ok up to half throttle but when try to kick down its like someone has turned off the gas.
any ideas.thanks
PostPosted: Mon Feb 22, 2010 1:09 am    Post subject: Reply with quote
Welcome to the board.
First thing to look for is vacuum leaks.
masterdave
PostPosted: Mon Feb 22, 2010 8:30 am    Post subject: Reply with quote
DME relay, im not sure but i think the fuel pump has 2 settings a sort of high and low pressure, but it sounds like a DME relay problem, they go all the time for no apparent reason, even if thats not the issue having a spare relay around is never a bad thing.
Mav666
PostPosted: Mon Mar 01, 2010 3:54 am    Post subject: Reply with quote
Agreed with the DME relay issue, I've started keeping one in my glove box, certainly worth getting hold of a known good one and giving it a try first
John_AZ
PostPosted: Mon Mar 01, 2010 10:16 am    Post subject: Reply with quote
switz60,
Your car sat for 8 months---in (wet) Ireland.
Did you use a fuel additive like Stabil or something to keep moisture out of the fuel?
You should change the fuel filter and as much of the gas as possible.
There is also an in tank filter screen that may be clogged and should be checked. Also the fuel pump check valve should be cleaned.
Your injectors may be clogged as well.
GL & welcome
John_AZ
1988 94S 61K + 1987 924S 114K DD
