i cant find my horn
paulsmaroon924
PostPosted: Fri Feb 26, 2010 10:23 am    Post subject: i cant find my horn Reply with quote
where in the name of God is the actual horn unit on the 1981 2.0na, i cant find the b"£tard, i need to check the unit because the horn isnt working at the steering wheel and the fuses are all good/replaced, hence the suspect device search.
please no replys saying "beep and listen to where the noise is coming from, thats the way I'd find it" as my neighbour suggested, moron.
or any other ideas keep em flowing lads, and ladies.
Cant afford Viagra before its suggested, or magnifying glasses, smartarse.
Shurick
PostPosted: Fri Feb 26, 2010 10:29 am    Post subject: Reply with quote
I would expect it in the left corner just under the valance. That's where they usually hide.
WBR, Shurick
'86 924S -- R.I.P.
https://www.instagram.com/ru_pacecar/
sbarc
PostPosted: Fri Feb 26, 2010 10:55 am    Post subject: Reply with quote
I'm not exactly sure how it is done on the 924's....but I had an old Toyota that had a horn that didn't work. The problem was a spring loaded brass pin that was connected to the steering column behind/under the steering wheel. On the backside of the steering wheel was a brass ring that rubbed against this brass pin that was connected the a wire that went to the horn. There was electrical lube on the brass ring and pin to make them last longer.....but the lube dried up and the pin worth down too much for the spring to push it against the brass ring on the steering wheel. I pulled the wheel.......applied power (or was it ground?) to the pin and the horn worked.....so I spent $3 on a new pin and the problem was solved.
I have no idea if this is your problem, but I'm assuming all cars use the same basic system, so this might be something for you to keep in the back of your mind.
So....if the horn does work when you give it power.....then check the contacts and horn button on the steering wheel. You'll probably annoy your neighbours as you keep hitting the horn to find the problem.
1981 931 (Canadian car)
1981 931 (US car)
1990 928GT (ROW car)
1991 Toyota MR2
1989 Toyota MR2 Super Charged
1985 Toyota Supra
1973 Triumph GT6
1971 Opel GT
9XX Girl!
PostPosted: Fri Feb 26, 2010 11:18 am    Post subject: Reply with quote
Please allow me to translate as this is as plain as day if you are American, but not so if you are Irish.
I assume your car is RHD
Pop the bonnet! Ok, now look in the area of the bottom of the windscrean on the drivers side. yep, underneath the bottom rail of the windscrean, in the hideaway where they bury the wiper linkage.
Yer, I know. Thats just what i was thinking
EDIT: let me know when you've got the horn paulsmaroon924
924 (84) N/A 2 ltr - 5 Speed - BLACK - Project (looking for 200BHP, any ideas!)
924 (81) N/A 2 ltr - 3 Speed Auto - SURINAM RED (Metallic) - Near Original Spec (sticking with originality)
BOTH ON THE ROAD, BOTH USED EVERY-OTHER DAY
PostPosted: Fri Feb 26, 2010 2:13 pm    Post subject: Reply with quote
That's exactly where the factory placed the horn for the alarm on my car.
The horns that get beeped from the steering wheel (you may find two, one high note and one low) I'd expect to find where Shurick described - behind the lower valence at the front-left corner.
JayZzzz4
PostPosted: Fri Feb 26, 2010 3:28 pm    Post subject: Reply with quote
Having the head lights on helps a little to see in there if your looking from the top
White 1987 Porsche 924S manual
PostPosted: Fri Feb 26, 2010 4:46 pm    Post subject: Reply with quote
+1
I have a mysterious empty bracket under the windscreen, but the actual horn module is front left corner.
paulsmaroon924
PostPosted: Fri Feb 26, 2010 10:06 pm    Post subject: Reply with quote
cheers guys ill get on that when i get back from work tomorrow, provided the missus lets me, havent seen her in a week because of our rosters.
(both work for different airlines)
ill let y'all know what i find and how it goes..... on the car.
cheers
ps Ta Paula, will do
924OZY
PostPosted: Sat Feb 27, 2010 1:15 am    Post subject: Reply with quote
No worries,
Just get one of those old "AAROOGA" horns that you squeeze and rivet it to your door or your steering wheel.
Best bolt on mod available!
924 N/A snailshell, superpro linkage bushes, 2.5"exhaust
4.0L ef Fairmont, 3000rpm stall, shift-kit, J3 chip, 3" exhaust, self tuned using tunerpro, soon to be boosted,
expecting 350Kw at wheels at 10psi.
PostPosted: Sat Feb 27, 2010 4:03 am    Post subject: Reply with quote
The 924 horns are lovely. Mine makes a very loud shrill
sportscar sound.. Anyone know the history behind them,
Were grafted over from the 911, or 914 or something.
