eli32112
Posted: Sun Feb 21, 2010 1:48 pm Post subject: tourqe tube shaft question |
| i am 16 and bought a 1982 924 (manual transmission) for my first car. just this week my dad and i were changing the clutch in the car. Once we got the clutch housing out my had noticed a grove going all the way around the shaft on the end that would be going in to the clutch unit. This grove is in the flat part at the end and it is half way ( their is a flat section on each side). This grove goes all the way around and my my dad has never seen anything like it. i was wondering it this was normal or if i need to buy another shaft for my car? |
Posted: Sun Feb 21, 2010 2:12 pm Post subject: |
Welcome to the board.
Can you post a picture? _________________ White 87 924S "Ghost"
eli32112
Posted: Tue Feb 23, 2010 12:51 pm Post subject: |
| i am not shur how to can you help i have plenty of pictures of the car |
Posted: Tue Feb 23, 2010 1:01 pm Post subject: |
Punch the email button under my post and send me a picture of the shaft. _________________ White 87 924S "Ghost"
eli32112
Posted: Tue Feb 23, 2010 1:11 pm Post subject: |
| their you go sent the email |
Posted: Tue Feb 23, 2010 1:20 pm Post subject: |
Has not arrived yet... _________________ White 87 924S "Ghost"
Posted: Tue Feb 23, 2010 1:31 pm Post subject: |
It was almost a 4 meg picture!!!
Sorry you will need to replace that and the pilot bearing.
eli32112
Posted: Tue Feb 23, 2010 1:34 pm Post subject: |
ok what is wrong with it and were can i get one/how much will it cost. none of the places i have bought any of my other parts have it |
Posted: Tue Feb 23, 2010 1:36 pm Post subject: |
Best bet is to post an ad in the parts wanted section for a used torque tube. Make sure you state the year of your car. _________________ White 87 924S "Ghost"
eli32112
Posted: Tue Feb 23, 2010 1:40 pm Post subject: |
| ok thanks alot for the info |
Fifty50Plus
Joined: 28 Feb 2008 Posts: 1425 Location: Washington DC area
Posted: Wed Feb 24, 2010 2:52 am Post subject: |
I've got an '82 931 (turbo) torque tube. Is your car a turbo model or normally aspirated? There is a difference in the shaft size between the two.
Edit: or is there with the Audi transmission?????
Chuck _________________ 1979 924 NA race car H-Prod SCCA
1982 924 NA race car - Sold
1981 924 Turbo sold
1982 924 Turbo sold
Posted: Wed Feb 24, 2010 3:15 am Post subject: |
Yep, the configuration on the torque tubes is different for the Audi gearboxes between the 931 and 924. The shaft diameter is 25mm vs 19mm respectively, and the input shaft on the 931 version of the box is longer, meaning that the driveshaft in the torque tube is actually a bit shorter on the 931 version.
eli32112, what year is your car, is it a Turbo or normally aspirated, and where in IL are you? Chances are we can find somebody that is parting out a car that can help you out with a used torque tube. _________________ erstwhile owner of just about every 924 variant ever made |
Slam
Posted: Wed Feb 24, 2010 6:39 am Post subject: |
I suggest buying the pilot bearing assembly - housing, needle bearing and seal as a complete unit. Expensive, and you'll wait forever to get the stupid thing, but it's better than trying to find the seal separately. Also, do a search for 'pilot bearing' on this site and read up on removing the old one. It's a PITA.
Some reading: http://www.924board.org/viewtopic.php?t=29562&highlight=
Check out the pics of the tool I used to get the pilot bearing out.
Good luck! _________________ '88 944 Auto - may or may not resurrect |
Posted: Wed Feb 24, 2010 10:39 am Post subject: |
He has a 82 924 and I doubt the pilot bearing is there anymore. _________________ White 87 924S "Ghost"
eli32112
Posted: Wed Feb 24, 2010 12:31 pm Post subject: |
| its a 1982 non turbo and in central il |
