the_mad_electrician
Posted: Wed Feb 24, 2010 11:28 am Post subject: Stupid question! |
This is probably the most stupid question ever asked, but What size Allen wrench fits the 924 head bolts? I stripped everything off a head I wanted to get out of the pull-a-part and found Allen heads and I don't own any Metric Allens so I need to know what size to buy. _________________ 81 924 N/A
2004 Ranger "Edge"
2005 Mazda 6 |
Rocco R16V
Posted: Wed Feb 24, 2010 11:43 am Post subject: |
there are a couple sizes of metric allens used on these cars, you should just buy a set.
I bought some craftsman allen sockets, these are much better than the cheap L keys, i use 'em more than you'd think.
i think the most common are 6 and 8, but i dont know about the head bolts sorry. _________________ "Government exists to protect us from each other. Where government has gone beyond its limits is in deciding to protect us from ourselves. "
Ronald Reagan |
the_mad_electrician
Posted: Wed Feb 24, 2010 11:46 am Post subject: |
thanks man I'll just get a set I probably need them anyway, and as deep as the bolt are I doubt the L keys would reach! _________________ 81 924 N/A
2004 Ranger "Edge"
2005 Mazda 6 |
Posted: Wed Feb 24, 2010 1:10 pm Post subject: |
I believe they are a size M10...I would second the suggestion to buy a complete set from Craftsman, as you're going to need them. _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Wed Feb 24, 2010 1:14 pm Post subject: |
Just confirmed, they are an M10 hex (Type 2). However, there were apparently some that were M10 triple square (12-point internal, aka Type 3). I have a special Porsche tool for those, so if you find out that they have the Type 3, I would consider letting you borrow the triple square that I have, since it's a pretty uncommon piece and not easy to find. _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Wed Feb 24, 2010 1:21 pm Post subject: |
| the_mad_electrician wrote: | | thanks man I'll just get a set I probably need them anyway, and as deep as the bolt are I doubt the L keys would reach! |
Uh, how would you use a torque wrench with a L key? _________________ White 87 924S "Ghost"
Rocco R16V
Posted: Wed Feb 24, 2010 2:24 pm Post subject: |
you can now find a three piece set of triple squares at harbor frieght.
these are also good to have in the tool box.
I know some vw axle bolts use these, do the porsche use triple square or regular allen head bolts on the axles? _________________ "Government exists to protect us from each other. Where government has gone beyond its limits is in deciding to protect us from ourselves. "
Ronald Reagan |
Posted: Wed Feb 24, 2010 2:59 pm Post subject: |
Triple square for the CV joints from the factory; many replace them with allens after stripping the triple square with the incorrect tool. _________________ 78 924 NA
5-lug |
Posted: Thu Feb 25, 2010 1:53 am Post subject: |
BTW, get a 1/2" drive unit for the head bolts. I broke three 3/8" versions taking the head off my car. _________________ Stefan
brupska
Posted: Thu Feb 25, 2010 7:28 am Post subject: |
| I just torqued mine down with a Torx head T50 or T45??? I used a socket driver. I can't remember which one it was!! I have a 81 924 NA if that helps!!! |
9XX Girl!
Joined: 20 Sep 2009 Posts: 1617 Location: Cornish Riviera SW England
Posted: Thu Feb 25, 2010 8:54 am Post subject: |
| !tom wrote: | | Triple square for the CV joints from the factory; many replace them with allens after stripping the triple square with the incorrect tool. |
Out of the 24 Try-square machine screws on the CV flanges on my car, only one has been replaced with a socket head machine screw. Can't remember where but i did read that socket screws can fail as they have six points of weakness due to a large socket hole compared to screw head size.
The reason for the use of Try-square machine screws is the heads are stronger in both relation to socket head (allen) and Torx as the socket hole is smaller compared to the screw head, resulting in a stronger head and more distributed focused points of weakness.
However, my odd socket screw is still OK spinning around on my O/S half shaft. It can be easily removed with the correct Tri-square bit (which is M8 Tri-square for CV joints screws).
oh... a 7mm hex key and a 22mm swan neck ring spanner are handy too for removing the top bracket of the MacFer struts.
But... i do prefer a "L" shaped key for the pinch nut on the front stub axials. Always worth carrying one in your tool roll. _________________ 924 (84) N/A 2 ltr - 5 Speed - BLACK - Project (looking for 200BHP, any ideas!)
BOTH ON THE ROAD, BOTH USED EVERY-OTHER DAY |
haroldk
Joined: 24 Nov 2008 Posts: 171 Location: St Paul, MN, USA
Posted: Thu Feb 25, 2010 9:10 am Post subject: |
| 9XX Girl! wrote: |
Well, the Ford Sierras (including the Cosworth RS and RS500) all used Torx screws in all 4 CV joints. They make more power than a 924 (even in factory detune) and I know some people here in the states using the factory CV joints on Merkur XR4Tis and running close to 500hp through them with allen-head screws without a failure.
That's all anecdotal, but I really doubt an allen-head screw is more failure-prone in that application than a tri-square. |
9XX Girl!
Posted: Thu Feb 25, 2010 9:24 am Post subject: |
| haroldk wrote: |
Well, the Ford Sierras (including the Cosworth RS and RS500) all used Torx screws in all 4 CV joints. |
hmmm... i was kind of skeptical when i read it plus, givin it a mention was sure to prompt a response. Some old Rovers use common old bolts. Wonder why Porsche and VW and Audi go for Try-Sq then? _________________ 924 (84) N/A 2 ltr - 5 Speed - BLACK - Project (looking for 200BHP, any ideas!)
the_mad_electrician
Posted: Thu Feb 25, 2010 11:06 am Post subject: |
| Paul wrote: | | the_mad_electrician wrote: | | thanks man I'll just get a set I probably need them anyway, and as deep as the bolt are I doubt the L keys would reach! |
Uh, how would you use a torque wrench with a L key? |
I don't plan on torqueing them I'm trying to get them off. I'll be going back with head studs when I reinstall the head. _________________ 81 924 N/A
2004 Ranger "Edge"
2005 Mazda 6 |
Posted: Thu Feb 25, 2010 11:14 am Post subject: |
Well done.
Just cut off a cheap 10 mm L key and use a socket. _________________ White 87 924S "Ghost"
