tourqe tube shaft question
eli32112
PostPosted: Sun Feb 21, 2010 1:48 pm    Post subject: tourqe tube shaft question Reply with quote
i am 16 and bought a 1982 924 (manual transmission) for my first car. just this week my dad and i were changing the clutch in the car. Once we got the clutch housing out my had noticed a grove going all the way around the shaft on the end that would be going in to the clutch unit. This grove is in the flat part at the end and it is half way ( their is a flat section on each side). This grove goes all the way around and my my dad has never seen anything like it. i was wondering it this was normal or if i need to buy another shaft for my car?
PostPosted: Sun Feb 21, 2010 2:12 pm    Post subject: Reply with quote
Welcome to the board.
Can you post a picture?
eli32112
PostPosted: Tue Feb 23, 2010 12:51 pm    Post subject: Reply with quote
i am not shur how to can you help i have plenty of pictures of the car
PostPosted: Tue Feb 23, 2010 1:01 pm    Post subject: Reply with quote
Punch the email button under my post and send me a picture of the shaft.
eli32112
PostPosted: Tue Feb 23, 2010 1:11 pm    Post subject: Reply with quote
their you go sent the email
PostPosted: Tue Feb 23, 2010 1:20 pm    Post subject: Reply with quote
Has not arrived yet...
PostPosted: Tue Feb 23, 2010 1:31 pm    Post subject: Reply with quote
It was almost a 4 meg picture!!!
Sorry you will need to replace that and the pilot bearing.
eli32112
PostPosted: Tue Feb 23, 2010 1:34 pm    Post subject: Reply with quote
ok what is wrong with it and were can i get one/how much will it cost. none of the places i have bought any of my other parts have it
PostPosted: Tue Feb 23, 2010 1:36 pm    Post subject: Reply with quote
Best bet is to post an ad in the parts wanted section for a used torque tube. Make sure you state the year of your car.
eli32112
PostPosted: Tue Feb 23, 2010 1:40 pm    Post subject: Reply with quote
ok thanks alot for the info
Fifty50Plus
PostPosted: Wed Feb 24, 2010 2:52 am    Post subject: Reply with quote
I've got an '82 931 (turbo) torque tube. Is your car a turbo model or normally aspirated? There is a difference in the shaft size between the two.
Edit: or is there with the Audi transmission?????
Chuck
1982 924 NA race car - Sold
1981 924 Turbo sold
1982 924 Turbo sold
PostPosted: Wed Feb 24, 2010 3:15 am    Post subject: Reply with quote
Yep, the configuration on the torque tubes is different for the Audi gearboxes between the 931 and 924. The shaft diameter is 25mm vs 19mm respectively, and the input shaft on the 931 version of the box is longer, meaning that the driveshaft in the torque tube is actually a bit shorter on the 931 version.
eli32112, what year is your car, is it a Turbo or normally aspirated, and where in IL are you? Chances are we can find somebody that is parting out a car that can help you out with a used torque tube.
Slam
PostPosted: Wed Feb 24, 2010 6:39 am    Post subject: Reply with quote
I suggest buying the pilot bearing assembly - housing, needle bearing and seal as a complete unit. Expensive, and you'll wait forever to get the stupid thing, but it's better than trying to find the seal separately. Also, do a search for 'pilot bearing' on this site and read up on removing the old one. It's a PITA.
Some reading: http://www.924board.org/viewtopic.php?t=29562&highlight=
Check out the pics of the tool I used to get the pilot bearing out.
Good luck!
PostPosted: Wed Feb 24, 2010 10:39 am    Post subject: Reply with quote
He has a 82 924 and I doubt the pilot bearing is there anymore.
eli32112
PostPosted: Wed Feb 24, 2010 12:31 pm    Post subject: Reply with quote
its a 1982 non turbo and in central il
