Posted: Fri Feb 12, 2010 11:23 pm Post subject: LOVE your Porsche! |
To celebrate St. Valentine's Day, and a massive upgrade to the website,
we're offering 10% discount on select items now through the end of February.
Here are the highlights:
10% off Appearance Packages- 924- and 931-specific Hood Liner Heat Shields: $53 (regularly $59)
- Domestic Carpet Kits: $377 (regularly $419)
- DIY German Vinyl Dash Recover Kit: $359 (regularly $399)
10% off Kingsborne Wiresets- 924 NA wireset: $56.70 (regularly $63)
- 931 wireset: $45 (regularly $50)
10% off IMI Hi-Torque Starters- IMI155-CW for 924 NA: $220.50 (regularly $245)
- IMI155-CCW for 931: $220.50 (regularly $245)
We've also added two important new sections to the site:
A section dedicated to performance modifications available for the 2.0L motors, including:- Big Valve Kit ($445)
- Crower Rods ($867)
- Diamond Pistons ($650-750 per set including pins, retainers and rings)
- Performance Exhaust by Stahl, Bursch & MSDS ($245-$575)
- Stroker Cranks ($500-$650)
This section of the site is designed to make it easier for you to order parts for rebuild projects.
We've organized common rebuild or restoration projects into Kits by Repair Group, including:- 924 NA & 931 Engine Rebuild Kits
- 924 & 931 Tune-up Kits
- 924 & 931 Cooling System Kits
- 931-specific turbo, wastegate, and vac line kits
You can order directly from the site, or by contacting us via email or PM with your specific needs. _________________ erstwhile owner of just about every 924 variant ever made
Posted: Fri Feb 12, 2010 11:54 pm Post subject: |
924 NA wireset: $56.70 (regularly $43) ?  _________________ Supercharger and EFI kits
Posted: Sat Feb 13, 2010 1:26 am Post subject: |
| morghen wrote: | 924 NA wireset: $56.70 (regularly $43) ?  |
Thanks, morghen, should have been "regularly $63". Fixed above. _________________ erstwhile owner of just about every 924 variant ever made |
PORSCHEV
Posted: Sat Feb 13, 2010 1:39 am Post subject: |
Have you installed one of these carpet sests yet your self? Quality ? fit? _________________ 1976 924
1978-#53 "D" track racer. |
DOCO
Joined: 04 Aug 2006 Posts: 1111 Location: Keswick Ontario Canada
Posted: Sat Feb 13, 2010 1:55 am Post subject: |
your getting some pretty cool stuff there dan!!!but i still have to do my 5 lug convertion first. _________________ Doco "where am i going and why am i in this handbasket"author unknown
79 924 N/A "Webster"
_______
/______\
[+]___[+]
\0 924 0/
[__]..[__]
"WEBB STR" |
Posted: Sat Feb 13, 2010 2:10 am Post subject: |
| PORSCHEV wrote: | | Have you installed one of these carpet sests yet your self? Quality ? fit? |
No, I haven't installed one yet, but I want to put one in the Euro car I just acquired. I can't comment on fit from first hand experience, but Bob (Classic 9 Leathershop) has gotten excellent reviews on all of his stuff for both the 924/44 and 928 platforms.
As for the quality, the German carpet kits are obviously a little nicer and fuller than the Domestic, but the Domestic kits are very nice, MUCH MUCH better than the cheap swill being peddled on FleaBay. I will probably go with the Domestic myself, as I'm not trying to do a concourse restoration. The Foss Spectropile stuff is very durable, high quality stuff, designed specifically for automotive and marine applications. _________________ erstwhile owner of just about every 924 variant ever made |
Elektrobank
Joined: 19 Mar 2007 Posts: 149 Location: Pozzuoli,Napoli, Italy
Posted: Sat Feb 13, 2010 6:25 am Post subject: Re: LOVE your Porsche! |
| ideola wrote: | [We've organized common rebuild or restoration projects into Kits by Repair Group, including:- 924 NA & 931 Engine Rebuild Kits
You can order directly from the site, or by contacting us via email or PM with your specific needs. |
a lot of interesting stuff!
i'm interested in 931 rebuild kit
what brands are the head gasket and crankcase set?
what we will find inside those sets?...manifolds gasket,head gasket, oil cooler oring, turbo orings, oil seals ...what else?
thanks  _________________ 924T Dta inj + sequential LPG
Cosworth
MotoMorini 501
Moto Morini 350 K2
lot of fun but always on foot.... |
Posted: Sat Feb 13, 2010 6:46 am Post subject: |
The 931 Rebuild Kit consists of:- Head Gasket Set (see below)
- Crankcase Gasket Set (see below)
- new cam oiler tube
- new cam oiler tube elbow
- new oil pan drain plug
- new oil pan drain plug crush washer
- two new locating sleeves for head gasket
I considered adding the freeze plugs to the list, but haven't had time to get pricing on them yet.
In any event, the 931 Headgasket Set (931 100 901 00) consists of:
068 103 085 A: sealing ring (1)
048 103 095: sealing ring (1)
060 198 025 A: set of seals (1)
931 104 337 06: cylinder head gasket (1)
046 109 675 A: valve stem seals with assembly sleeve (
931 110 147 00: gasket (4)
931 110 152 01: gasket (1)
930 111 191 01: gasket (4)
048 121 127 A: gasket (1)
048 905 341 B: gasket (1)
993 111 195 00: sealing ring (1)
931 123 193 05: gasket (1)
931 111 191 10: gasket (1)
999 701 473 40: round seal (1)
056 905 261: gasket (1)
Haven't looked all those up, but it's basically everything for the top end: intake gaskets, exhaust gaskets, throttle body, all the charge tube o-rings and gaskets, CSV gasket, etc.
The Crankcase Gasket Set (060 198 041 A) consists of the oil pan gaskets, front and rear main seals, water pump gasket, oil pump gasket, oil pickup gasket, drain plug crush washer, and a few other miscellaneous seals and o-rings.
The brand for both will be either Goetze or Victor Reinz. I can't really request one over the other, it's whatever the supplier has access to at the moment. HTH... _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Mon Feb 15, 2010 11:52 pm Post subject: |
Hope you all had a great Valentine's Day...it's not too late to still Love Your Toofah Discounts run through the end of the month  _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Fri Feb 19, 2010 3:20 am Post subject: |
I received a couple of inquiries regarding the turn around on some of the Classic 9 products.
The carpet sets are hand cut and prepared, and require ~3-week turn around from time of order to shipment.
The hood liners are also hand cut, and require ~3-day turn around from time of order to shipment. _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Mon Feb 22, 2010 11:43 pm Post subject: |
One week left, still time to take advantage of the discounts  _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Thu Feb 25, 2010 5:05 am Post subject: |
Only four more days left to LOVE your TOOFAH  _________________ erstwhile owner of just about every 924 variant ever made |
