924sjoshawa
Joined: 19 Jan 2010 Posts: 12 Location: springfield, IL
Posted: Fri Feb 26, 2010 5:51 am Post subject: cant start!!!! |
| k i have checked for spark its there. i have tryed and tryd to start evey once in awhile it starts were talkin 1 in 200 maybe. i checked for fuel with dme relay didnt seem to be any. i jumped dme relay and wa la fuel! still no start tho. i dont know whitch dme relay to get. it is a 87 924s |
Posted: Fri Feb 26, 2010 6:37 am Post subject: |
How many miles on your motor? Did you buy it non-running, or did this problem just develop? How do the plastic plugs for the speed/reference sensors look?
DME relay is pretty generic, you should be able to get one for $30 or so. _________________ Toofah King Bad
joecitizennn
Posted: Fri Feb 26, 2010 10:02 am Post subject: |
| I have piles of relays and sensors at my house to check the car with. I live close to you. Have you ever had the car running at all? |
924sjoshawa
Posted: Fri Feb 26, 2010 1:59 pm Post subject: |
| yes it ran fine. i had been driving it for about 6 weeks then became hard to start. now wont start at all. that would be awsome if you could help me joe. i dont realy have alot of money right now im getting ready to leave for basic training. but would love to buy a couple relays and sensors from you if posible. it says 72k but it dosnt work. po told me it had foes done 3k miles back but im gonna read into it and do it agin to be safe. |
masterdave
Posted: Sat Feb 27, 2010 6:15 am Post subject: |
| sounds like a relay issue, i had the same issue about 3 months ago and it turned out that some one had connected an extra wire to the live connection on the fuel pump inadvertently drawing current from it, this caused the pump to not work so well when the relay was in but fine when i jumped it. Get under the passenger side behind the rear wheel you will see the pump. take the connectors off, one per connection, and clean with a wire brush, you may just have an intermittent connection. Its a quick check and could solve a lot of issues. |
Mav666
Joined: 16 May 2008 Posts: 47 Location: Newcastle, UK
Posted: Mon Mar 01, 2010 3:53 am Post subject: |
Always worth checking the reference sensor as well  |
joecitizennn
Posted: Mon Mar 01, 2010 5:27 am Post subject: |
| just a crazy thought, unplug the electrical connector to your number one injector and see if the car will stay running at a rough idle. |
924sjoshawa
Posted: Tue Mar 02, 2010 5:12 am Post subject: |
| naw it wont start that way. i think its the relay or maybe a ref sensor |
Posted: Tue Mar 02, 2010 6:16 am Post subject: |
Have you pulled the cap to check it and the rotor? My previous S did a slow death on starting, took forever, and turned out to be said parts. _________________ '83 944 Track car.
2001 Ford F350 powerstroke |
Mav666
Posted: Tue Mar 02, 2010 8:17 am Post subject: |
Have a look at Clarks it explain how to do a quick multi meter check of the ref. sensors.
They're not cheap and hard to come by 2nd hand but if you find that the BG one is duff then that will be your problem, its the BG thats the one that sends the signal to the ECU.
If the DG one is good they so long as you can get them out you can swap them over.
Failing that as its been said try and get hold of a spare DME and try that.
GL |
skytrooper
Joined: 29 Aug 2007 Posts: 461 Location: Canandaigua, NY
Posted: Tue Mar 02, 2010 9:38 am Post subject: |
I had a very similar problem with my "83 944 last fall. I tried everything, but the reference sensor. Once I changed it out...she started right up and has ever since. Do your research...if you buy the BMW sensor it will save you a lot of dough
BMW part number is 12-14-1-708-619
German Auto parts has them for 66.07 + s/h (look it up under BMW 633i)
or you could go to Pelican parts and get the Porsche one (no difference) for 168.25...it is your call _________________ Matt
1987 - 924S "Black Pearl"
1982 - BMW 633CSi
1984 - BMW 528e
1976 911S Targa (Gone) |
