Key differences between a US spec 931 and a ROW 924 turbo?
931Owner
PostPosted: Fri Apr 02, 2010 2:04 pm    Post subject: Key differences between a US spec 931 and a ROW 924 turbo? Reply with quote
I've read a lot but can't really put my finger on why the 931 makes 150 hp and the ROW with 170 hp.
Timing seems an obvious difference but what else was there?
1980 Turbo
-too many cars and too many motobikes
924guy
PostPosted: Fri Apr 02, 2010 10:27 pm    Post subject: Reply with quote
half a point compression increase in the row cars, slightly different pistons.
Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
Performance by Pasha
Nein37
PostPosted: Fri Apr 02, 2010 11:37 pm    Post subject: Reply with quote
Mostly due to stock boost levels. S2 Specs:
US cars run 7 psi or .5 BAR 156hp
Euro cars run 10 psi or in Euro speak .65 BAR 177hp
Put a boost gauge and a manual boost controller in your US car, turn it up to 10 psi and enjoy. You'll need to run on 93 octane. You would probably be safe at 11psi since the US cars have a lower compression ratio.
Intercooled model specs:
Carrera GTs ran 12.5 PSI or .85 BAR 210hp
Carrera GTS ran 14.5 PSI or 1 BAR 245hp
Carrera GTS CS ran 16 PSI or 1.1 BAR 270hp
1981 931 CGT replica, OEM CGT intercooler, .8 BAR WG spring, GTS Headlights, Innovative Wide band A/F, A/C delete, 16" Fuchs, Weltmeister 200lb lowering springs, Bilstein HDs front, Koni Sport rears.
PostPosted: Sat Apr 03, 2010 1:05 am    Post subject: Reply with quote
As above: higher 8.5:1 CR (vs. 7.5:1 in S1 US and 8.0:1 in S2 US); .8 bar wastegate spring as opposed to .6 bar in US trim; and different DITC board. And I believe the BHP numbers are 177 in Euro trim and 156 in US.
9xx
PostPosted: Sat Apr 03, 2010 1:18 am    Post subject: Reply with quote
Row S1 0.7 bar.
Row S2 0.65 bar (this is verified by my VDO boost gauge.)
Mikko
Shurick
PostPosted: Sat Apr 03, 2010 9:06 pm    Post subject: Reply with quote
S1 ROW (M31.01): CR 7.5:1, 0.75 bar of boost, K26-2470R6.10 turbocharger
S1 US (M31.02): CR 7.5:1, 0.45 bar, K26-2660GA4.10 turbocharger
S2 ROW (M31.03): CR 8.5:1, 0.65 bar, K26-2664G4.10
S2 US (M31.04): CR 8.0:1, 0.45 bar, K26-2660GA4.10
S1 had ignition distributors with different curves of ignition for US and ROW. S2 had different ignition modules.
WBR, Shurick
'86 924S -- R.I.P.
https://www.instagram.com/ru_pacecar/
