Fuel pump questions??
brupska
PostPosted: Sun Feb 14, 2010 1:07 am    Post subject: Fuel pump questions?? Reply with quote
I have a couple questions. I don't know the color codes for a 81 924 NA fuel pump. Black with green tracer and I think the other one is Red or Orange. Which one is - and +? The next question is. Does the Fuel tank have a barb on the it where the hose is comming out of the tank? I am in the process of installing a inline low pres. pump and the outlet hose is dryrotted. I don't want to just cut it off and mess up this hose until I know I can replace it!!! I don't see a hose clamp on it that is why I am asking?
PostPosted: Sun Feb 14, 2010 3:04 am    Post subject: Reply with quote
The "S" shaped hose can be bought from Porsche new for around $15, and should have a clamp.
brupska
PostPosted: Sun Feb 14, 2010 4:13 am    Post subject: Reply with quote
Well its not a S shaped hose anymore. LOL It dry rotted at the external pump end. There was one hose clamp, it was on the ext pump end. Thanks Rasta
!tom
PostPosted: Sun Feb 14, 2010 5:03 am    Post subject: Reply with quote
Brown is ground.
Everywhere in the car.
78 924 NA
5-lug
9XX Girl!
PostPosted: Sun Feb 14, 2010 6:58 am    Post subject: Reply with quote
!tom wrote:
Brown is ground.
Black with green tracer is positive (+) according to the wiring diagrams.
The Red or Orange is probably not stock and someone has used it to replace the brown ground (-)
924 (84) N/A 2 ltr - 5 Speed - BLACK - Project (looking for 200BHP, any ideas!)
BOTH ON THE ROAD, BOTH USED EVERY-OTHER DAY
brupska
PostPosted: Sun Feb 14, 2010 9:04 am    Post subject: Reply with quote
Thank you all for the info! 9XX Girl I think it may be brown. Its just hard to tell in a dark garage with my drop light! Thanks again Brad
PostPosted: Sun Feb 14, 2010 11:17 pm    Post subject: Reply with quote
I have NEVER seen a 924 with a PO astute enough to know that a ground wire would need replacing.
brupska
PostPosted: Mon Feb 15, 2010 1:23 am    Post subject: Reply with quote
My ground wire is brown. I just had a hard time seeing it in the dark with only my drop light. I couldnt tell the color at first. Thanks Brad
