timing 82 na
windwaiver
PostPosted: Sat Feb 13, 2010 4:13 am    Post subject: timing 82 na Reply with quote
Anyone set it by the light, what do you set it at. I know the car says 0 deg, just wondering if you get the proper results by setting it here?
77.5 924 NA
81 924 na (great parts car)
82 924 NA
87 944S this is gonna cost
00 K1200LT
If i had a nickel for everytime I screwed up.......
PostPosted: Sat Feb 13, 2010 7:46 am    Post subject: Reply with quote
Vacuum lines connected, idle at 950, timing should be at '3' on the flywheel (3° ATDC). At 5000, vacuum lines DISCONNECTED, you should see total mechanical advance to 41° BTDC.
windwaiver
PostPosted: Sat Feb 13, 2010 12:32 pm    Post subject: Reply with quote
thanks!
77.5 924 NA
82 924 NA
00 K1200LT
