dreamgts
Posted: Fri Jan 29, 2010 1:01 pm Post subject: Fuel pump for weber installation |
Since Im converting to webers I have to change the fuel pump. My queries are as follows. Should I attache the new pump where the old pump was using also the old electrical conections? or should I re route it to the engine bay? If I re route it to the engine bay shall I connect the pump to the old cis fuel piping meaning after the fuel filter and then to the webers? any other alterations I need to do here is much appreciated Since Im putting everything on paper before starting the real work ( Im still sourcing some stuff actually). I have a high pressure weber pump, will this do for the weber carbs?
dreamgts _________________ 2 PORSCHE 924 (CURRENT PROJECTS)
2 CLASSIC CORTINAS (FINISHED)
1 CLASSIC FIAT(FINISHED)
1 CLASSIC FIAT 132 2000CC(JUST PURCHASED)
4 SUV'S
2 SEDANS
1 OPEL PANEL VAN
WIFES SUZUKI ALTO |
Rocco R16V
Posted: Fri Jan 29, 2010 3:46 pm Post subject: |
I would use something like this in the stock location
fuel pump link
you dont want to use a high preesure efi pump with carbs. Dont forget the fuel pressure regulator (FPR) needs to be for carbs also. _________________ "Government exists to protect us from each other. Where government has gone beyond its limits is in deciding to protect us from ourselves. "
Ronald Reagan |
DOCO
Joined: 04 Aug 2006 Posts: 1111 Location: Keswick Ontario Canada
Posted: Fri Jan 29, 2010 11:01 pm Post subject: |
you want to use a low pressure pump for webers. im useing a 2 to 6 lb pump that is adjustable.i did get your pm but just havent replied yet as i have not done the work.its to cold outside and springs coming!!anyway ill be removeing the old fuel pumps at rear and will be puting my pump at this location.i will use original fuel lines,one only for the fuel delivery,no need for rreturn.replace the original fuel filter and mount a nice custom see through one there.maybe a gauge after the filter.will be useing original wiring and wire up pump to that.there are some pictures coming my way of anouther install,when he gets time.i will ask him again.someone also asked about linkage,again havent got that far but will be soon looking at them and desiding what to do there.i have a good idea but i want to see if i can make it work first.im puting the pump at the rear of car as it will be easier for pump to push than pull. _________________ Doco "where am i going and why am i in this handbasket"author unknown
79 924 N/A "Webster"
_______
/______\
[+]___[+]
\0 924 0/
[__]..[__]
"WEBB STR" |
brupska
Posted: Fri Jan 29, 2010 11:51 pm Post subject: |
| I am glad I am on this board!!! I am doing the weber install too. I didn't know I needed to change my fuel pump. I do have a regulator to insall. I was gonna try plugging up the old return line and using the old pump. If doesn't work then I will get one that is in the link above. Thanks guys Brad |
Rocco R16V
Posted: Sat Jan 30, 2010 11:17 am Post subject: |
the regulator should have a provision for return, if not you can add a restrictor to the return line but dont eliminate it. lots of old carb set-ups dont have a return, but its better for pump life to have one.
the high pressure CIS pumps would absolutley need a return line if used with a carb regulator. life would be measured in minutes if not. _________________ "Government exists to protect us from each other. Where government has gone beyond its limits is in deciding to protect us from ourselves. "
Ronald Reagan |
brupska
Posted: Sat Jan 30, 2010 2:22 pm Post subject: |
| What kind of ristricter can I install? I am gonna try it with out for awhile. |
brupska
Posted: Sun Jan 31, 2010 1:23 am Post subject: |
| How bout intalling a T fitting before the pressure regluator. One line will go to the reg. the other will go back to the pump return? |
dreamgts
Posted: Sun Jan 31, 2010 4:55 am Post subject: Fuel pump for weber installation |
| Rocco R16V wrote: | I would use something like this in the stock location
fuel pump link
you dont want to use a high preesure efi pump with carbs. Dont forget the fuel pressure regulator (FPR) needs to be for carbs also. |
I was going to use a Facet fuel pump at the rear where the original pump was, I guess thats ok, Should I remove the original FPR, I was actually going to leave it in place, i dont know if this would affect the non original pump.
This is how I planned my installation, Tank to Facet Pump To Original FPR thru original fuel line to custom filter (can I leave the original filter) to weber installation.
4 SUV'S
2 SEDANS
1 OPEL PANEL VAN
WIFES SUZUKI ALTO |
Rocco R16V
Posted: Sun Jan 31, 2010 12:04 pm Post subject: |
what car? did it have cis?
the FPR needs to match what the carbs want. _________________ "Government exists to protect us from each other. Where government has gone beyond its limits is in deciding to protect us from ourselves. "
Ronald Reagan |
brupska
Posted: Sun Jan 31, 2010 12:25 pm Post subject: |
| Its a 1981 Weissach edition. The CIS was a basket case. The previous owner took it apart becasue the fuel dizzy was filling up the engine with fuel. I took it the rest of the way out and purchased a Redline Weber kit k294 off ebay that was brand new in the box $660 not bad. The linkage is the only real problem. I stole the throttle cable perch from the CIS and put it on the front of the stack bolt. Now I just need to fabricate a bell crank to push the carbs down instead of mounting a longer cable install. I will try this first then go to a longer cable for $40 From CSR . I am sorry I don't know the abbrviation for FPR. LOL |
Rocco R16V
Posted: Sun Jan 31, 2010 2:39 pm Post subject: |
FPR = fuel pressure regulator _________________ "Government exists to protect us from each other. Where government has gone beyond its limits is in deciding to protect us from ourselves. "
Ronald Reagan |
brupska
Posted: Sun Jan 31, 2010 3:54 pm Post subject: |
| lol ok Yes the FPR is a adjustable one for 1 to 5 psi. I am sorry I am not used to that abbriviation!! The manual says to run 2psi unless you are racing then 3 psi. |
dreamgts
Posted: Sun Jan 31, 2010 10:12 pm Post subject: Fuel pump for weber installation |
| brupska wrote: | | lol ok Yes the FPR is a adjustable one for 1 to 5 psi. I am sorry I am not used to that abbriviation!! The manual says to run 2psi unless you are racing then 3 psi. |
Ok so since Im gonna do a bit of racing and fitting a supercharger I think Im gonna need an FPR which is adjustable. Did you fit the new FPR instead of the original CIS one fitted to the car, may I know were you bought it from?
4 SUV'S
2 SEDANS
1 OPEL PANEL VAN
WIFES SUZUKI ALTO |
brupska
Posted: Mon Feb 01, 2010 1:09 am Post subject: |
| I am fitting a aftermarket one on. It is a spectre one with a dial on the face of it to adjust the pressure. |
