924OZY
Joined: 24 Jan 2010 Posts: 71 Location: Gold Coast Australia
Posted: Sat Jan 30, 2010 11:30 pm Post subject: Previous owner has messed up the timing big time |
Hello,
I have just tried to do the timing on my 79 924 na and when the timing light lights up, the timing marks are about 180deg out,
done dodgily by the previous owner, problem is I don't know what the fu*k he has done!
Also when the cam marks line up the timing marks are about 180deg out on the crank.
It still runs and drives but I can't set the timing till I fix it any Ideas? _________________ 924 N/A snailshell, superpro linkage bushes, 2.5"exhaust
4.0L ef Fairmont, 3000rpm stall, shift-kit, J3 chip, 3" exhaust, self tuned using tunerpro, soon to be boosted,
expecting 350Kw at wheels at 10psi. |
924OZY
Posted: Sun Jan 31, 2010 1:33 am Post subject: |
I know I can take the belt off and line it up properly with the cam pointer,
then check where the dist. rotor button is pointing, at TDC
Then fit the cap and start from there,
but heard it still be 180deg out if done that way?
Is there some sure fire way to get it right first time?
Seems like the previous owner has done nearly everything wrong so far.  _________________ 924 N/A snailshell, superpro linkage bushes, 2.5"exhaust
Posted: Sun Jan 31, 2010 2:44 am Post subject: |
| Quote: | | Also when the cam marks line up the timing marks are about 180deg out on the crank. |
Just some common noo-b confusion there.. I made the same mistake with my first car (a '70 Fiat 124 Sport Spyder) in about 1977.
Fact is the crank turns twice for each single revolution of the cam. -So just turn the engine until the cam tdc mark lines-up - then you'll find the cranks' tdc is also lined-up. It has to be correct, or very close, oe else it wouldn't be running at all.
The correct cam mark is on the rear of the cam sprocket, and located at a "valley" between two of the teeth. _________________ "..it's made in Germany. You know the Germans always make good stuff."
924OZY
Posted: Sun Jan 31, 2010 3:20 am Post subject: |
Thanks,
but that doesn't solve the problem.
I know about the cam mark at the back of the sprocket,
but it must still be out,
because the marks on the flywheel are about 180 out when the timing light goes off.
Thats the Problem
Could he have put the flywheel on incorrectly? _________________ 924 N/A snailshell, superpro linkage bushes, 2.5"exhaust
Posted: Sun Jan 31, 2010 5:11 am Post subject: |
Yes, there are 6 flywheel bolts, and nothing to keep it from being re-installed incorrectly. -So it could be on there correctly, or any of 60, 120, 180, 240, or 300 degrees off. You can still check the timing with an adjustable strobe timing light, or by using the back of the cam sprocket and valve cover pointer. I have a pic around here somewhere...
Crank tdc can be verified manually with a wooden dowel through the #1 spark plug hole (for verifying correct timing belt installation). _________________ "..it's made in Germany. You know the Germans always make good stuff."
avaconirl
Posted: Sun Jan 31, 2010 8:09 am Post subject: |
| You say you are using a timing light. I take it you have it on no 1 plug lead and you are trying to set the distributer timing , if so put the lead onto no 3 plug lead. |
924OZY
Posted: Sun Jan 31, 2010 3:18 pm Post subject: |
Thanks heaps for that.
I am glad I didn't just take the flywheel marks as correct,
as I am sure thats what he has done wrong.
I guess I will draw another line where real top dead center is,
to make it easier in the future. Maybe on the front pulley too.
I will also try using no3 lead for the light as suggested.
Thanks again _________________ 924 N/A snailshell, superpro linkage bushes, 2.5"exhaust
avaconirl
Posted: Sun Jan 31, 2010 6:05 pm Post subject: |
Sorry i had brain fade when i said that to you !!!!!!!! I have a flu.
You should but the light on No 2 or No 4 thease are on the opposite plane i.e. 180 deg out from No 1.
P.S. I hope you dont mind me saying that No 1 IS at the front.
I hope this is of some help. |
924OZY
Posted: Sun Jan 31, 2010 7:17 pm Post subject: |
G,day
To solve the timing problem I had to forget logic.
The previous owner just chucked the flywheel on however, and none of the marks line up, even when using no3 lead for the light. (I tried, it would fire but was rough). Tip here, dont assume anything, check TDC to be sure!!!
To find TDC I took out the no 1 spark plug and used a pencil to find where the piston was at its highest while rotating the crank pulley with a ratchet, socket+ extension, then wrote a new line on the crank pulley at tdc, (using nailpolish)
This also showed that the cam timing was ok.
Then I had to use this line, with the timing light to set the timing.
I drew a circle on a piece of cardboard the size of the crank pulley,
then drew lines to see 90deg, then broke that up to see how far 10deg would be (about 10mm). So then adjusted the timing using the timing light on the crank pulley, so it lit up when the line was around 10mm before TDC on the pointer.
Was a big Pain in the arse as nothing was as it should be. I'm sure glad I didn't try to set up the cam timing believing the flywheel marks!!!
I am sure this will happen to others, so don't believe everything you read, check to be sure!!! _________________ 924 N/A snailshell, superpro linkage bushes, 2.5"exhaust
avaconirl
Posted: Sun Jan 31, 2010 7:28 pm Post subject: |
| Glad to see that you have sorted it out. It sometimes helps to look at these thing from a different angle, also it keeps the old brain ticking over. |
924OZY
Posted: Sun Jan 31, 2010 8:09 pm Post subject: |
Thats for sure,
my brain is hurting now
Probably increases your mental capacity working on Porsches.  _________________ 924 N/A snailshell, superpro linkage bushes, 2.5"exhaust
Posted: Sun Jan 31, 2010 11:49 pm Post subject: |
TDC is marked on the crank pulley. It cant be fit wrong. _________________ Porsche 924 1984 (UK import) NA
924OZY
Posted: Mon Feb 01, 2010 12:27 am Post subject: |
Roger that,
I'm sticking (stuck) with using the mark on the Pulley,
as they can't be fitted wrong.
Thats also what I am used to,
All my other cars had their timing mark on the pulley.
And I guess thats probably why most manufacturers do it that way,
It cant be fitted wrong!
Damn Flywheel.
Why doesnt it have a dowel or something so it can only go on one way?
I am not fixing it yet. _________________ 924 N/A snailshell, superpro linkage bushes, 2.5"exhaust
Posted: Mon Feb 01, 2010 5:17 am Post subject: |
That pic for checking timing at the rear of the cam sprocket -
Scorpio
Posted: Mon Feb 01, 2010 8:57 am Post subject: |
| Smoothie wrote: | Yes, there are 6 flywheel bolts, and nothing to keep it from being re-installed incorrectly. -So it could be on there correctly, or any of 60, 120, 180, 240, or 300 degrees off. You can still check the timing with an adjustable strobe timing light, or by using the back of the cam sprocket and valve cover pointer. I have a pic around here somewhere...
Crank tdc can be verified manually with a wooden dowel through the #1 spark plug hole (for verifying correct timing belt installation). |
Smoothie , when indexingh the flywheel is it best to have the 0 degree mark lined up with the pointer when crank it TDC and Cam is set TDC aswell? _________________ 1979 NA
MS1..EFI..
GARRETT T25 TURBO
BILSTEIN SHOCKS
GT BASED CUSTOM BODYKIT
Brisbane , Australia
Think mean think fast
all youll see is
my Porsches Arse!!! |
