Oil Pressure Gauge and Clock removal??
Coolbri1191
PostPosted: Sun Apr 18, 2010 12:21 pm    Post subject: Oil Pressure Gauge and Clock removal?? Reply with quote
How do you remove the oil and clock gauges? They need replacement bulbs.
I found the obvious two screws next to the gauges but what next?
and I need to replace the heater/fan control bulbs as well.
Guards Red 1987 Porsche 924S (Automatic)
2001 Ford Explorer Sport (DD)
edredas
PostPosted: Sun Apr 18, 2010 2:38 pm    Post subject: Reply with quote
Remove the two screws where the radio is, as well as the knobs for the climate controls, then remove the plate. Behind it, you will see two more screws that need to be removed before the gauge cluster can come out.
'84 944 -Red, Automatic
'87 924S -Red, 300hp 951 swap
'87 924S -Red, Project Car
'88 924S -Red, Daily Driver
Coolbri1191
PostPosted: Sun Apr 18, 2010 7:26 pm    Post subject: Reply with quote
I already have no radio installed, so the next thing I do is pull off the fan knob, remove plate, and then the two screws?
EDIT:
Pulled off fan knob, how do I get the three other fan controls off? (ones that slide) I just don't want to break anything.
edredas
PostPosted: Mon Apr 19, 2010 6:55 am    Post subject: Reply with quote
Having the radio out will make it alot easier to get at the two screws that are located at the bottom of the plate...
As for removing the other knobs, try to position them in an area you will remember before removing; (this will make putting them back sightly easier) then gently slide them out.
Coolbri1191
PostPosted: Mon Apr 19, 2010 7:09 am    Post subject: Reply with quote
I feel really dumb right now.
There's the two knobs that control airflow and there's the heater temp knob below that, and then the plate behind that.
I feel the two screws you are talking about underneath all of that (top side of where radio would be) but I can't unscrew them from that angle.
Do I really just ...gently slide the whole thing out?? Like, slide everything with the temp knobs (minus the fan speed knob) at once?
edredas
PostPosted: Mon Apr 19, 2010 7:16 am    Post subject: Reply with quote
It's better to pull the knobs out individually... then after the screws are loosened/removed the plate will just come off.
Coolbri1191
PostPosted: Mon Apr 19, 2010 7:22 am    Post subject: Reply with quote
So those knobs just pull out eh? Alright sounds simple enough.
EDIT:
Knobs came off with some effort. Noted where they go when everything is put back. Got a total of 6 screws ALTOGETHER taken off, but the top part with Clock and Oil Gauge will not come off. It is loose, but will not come off like as if something is still holding it in place......
edredas
PostPosted: Mon Apr 19, 2010 8:43 am    Post subject: Reply with quote
I don't recall there being anything else holding it in... just try and wiggle it back and forth and it should come out.
joecitizennn
PostPosted: Fri Apr 23, 2010 10:40 pm    Post subject: Reply with quote
EDIT:
You have to give it a good yank for it to pop off. They are all like that.
PostPosted: Sat Apr 24, 2010 12:32 am    Post subject: Reply with quote
There are two clips molded into the inner lower edge of the upper gauge bezel that will make it difficult to remove. Be careful, as too much force will cause the center console to crack. Better to do this on a warm day when the plastic won't be so brittle. The technique that seems to work for me is to sort of "fold" the gauge bezel down toward you, almost like when you open the glove box. Then with some gentle and persistent tugging and rocking side to side, it the two clips should let go.
Coolbri1191
PostPosted: Sat Apr 24, 2010 5:02 am    Post subject: Reply with quote
Thanks guys, I ended up getting it off that day, but my post disappeared here
