jrrhdmust
Joined: 19 Mar 2008 Posts: 180 Location: Middle Georgia
Posted: Tue Jan 26, 2010 2:39 am Post subject: Question for the experts |
I have now owned my 924s for about 2 years. Love the car.
Anyway, twice now parked nose up at about a 15 degree slope, with a 1/4 tank of fuel or so, I could not get the car started. I will turn over but not start. When I move the car to level, it still wont start imediately, but will after a couple of hours.
Is this a coincidence, and I need to roll up my sleeves and grab my multi-meter? or is there a normal explanation, and I need to avoind those circumstances?
Thanks! _________________ 67 Mercury Cougar XR7 under Restoration
71 VW Superbeetle Completed Resto 11/07
73 Mustang Mach 1 10 Year old restoration |
Rich H
Posted: Tue Jan 26, 2010 2:49 am Post subject: |
Sounds like a hot start problem. _________________ 1994 Lotus Esprit S4 - Work in progress...
Posted: Tue Jan 26, 2010 2:51 am Post subject: |
15° is actually pretty steep...no in-tank fuel pump or accumulators on the later cars...I'd guess you're starving the pump for fuel, maybe introducing a vapor lock condition? _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Tue Jan 26, 2010 4:12 am Post subject: |
More info is needed to properly diagnose. When you are getting "no start," you need to see if the coil is firing (most easily done with timing light) and if you are getting fuel pressure.
Quickest test would be to reach into your glovebox, swap in your spare DME relay, and see if the problem persists. _________________ Toofah King Bad
jrrhdmust
Posted: Tue Jan 26, 2010 4:23 am Post subject: |
When there was a no start condition I put my hand on the relay and felt it click. Like I said I am trying to determine if the slope maybe pulled fuel away from the pickup at a 1/4 tank, or if I need to start checking the fuel system. _________________ 67 Mercury Cougar XR7 under Restoration
gohim
Posted: Tue Jan 26, 2010 7:26 am Post subject: |
| Might be nothing wrong but a combination of low fuel level, AND excess water/non-combustible liquids on the bottom of the tank (that is exposed to the fuelpump pickup due to the extreme angle of parking). |
jrrhdmust
Posted: Tue Jan 26, 2010 11:49 pm Post subject: |
| gohim wrote: | | Might be nothing wrong but a combination of low fuel level, AND excess water/non-combustible liquids on the bottom of the tank (that is exposed to the fuelpump pickup due to the extreme angle of parking). |
That is kind of what I was thinking. I was just looking for a possible logical reason for the problem. If there wasn't one, I was going to go through and test all the components of the fuel system - again.
Thanks again! _________________ 67 Mercury Cougar XR7 under Restoration
Posted: Wed Jan 27, 2010 12:13 am Post subject: |
Might be a good idea to go ahead and drain the tank now, start with a clean slate... _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Wed Jan 27, 2010 2:41 am Post subject: |
| jrrhdmust wrote: | | Like I said I am trying to determine if the slope maybe pulled fuel away from the pickup at a 1/4 tank |
Seems unlikely with the large bottom well in the toofah tank, also does not explain why it doesn't fire right up when releveled. These pumps flow huge amounts of fuel (enough for a 951 on boost), so even if they are momentarily dry, they should recover immediately.
If your DME is good, I would suspect the pump. _________________ Toofah King Bad
masterdave
Posted: Wed Jan 27, 2010 4:00 pm Post subject: |
| i had a similar problem, turned out some one had basically grounded both connections on my fuel pump so it was not driving at full pressure, so up hill it had to work harder but downhill there was enough help from gravity to drip the gas in, i would agree and say check your filter first, then check fuel pressure, from there move to Relays and connections could be a power issue some where in the cabling you are losing power and not running your pump at full potential. |
jrrhdmust
Posted: Wed Jan 27, 2010 11:51 pm Post subject: |
ok Thanks!
I will check the fuel pump. I have rewired or replaced the rest of the fuel injection system just a little over a year ago. At that point I tested the pump and it was still good. I also replaced the filter then. _________________ 67 Mercury Cougar XR7 under Restoration
masterdave
Posted: Thu Jan 28, 2010 5:57 am Post subject: |
| if you have done all that i would check the lines for leaks, defiantly check pressure at the fuel rail |
jrrhdmust
Posted: Tue Feb 02, 2010 5:46 am Post subject: |
Update: I didn't check the fuel pressure, I did check the flow rate it was fine.
Here is what I think happened. It sitting at the wierd angle I try and start to no avail - about 3 times. Then I move it to the street, slightly nose down a couple of degrees nothing. A few hours later she fires right up.
I think that crap gas was flowing into the engine. I tried to start it enough that I flooded it, so it would matter where it was sitting. Once the fuel evaporated it fired right up.
When I drove it this weekend, there was misfire and hesitation. After a while it smoothed out. I then filled the tank and have not had any more problems. _________________ 67 Mercury Cougar XR7 under Restoration
masterdave
Posted: Tue Feb 02, 2010 9:48 am Post subject: |
| you may want to check your injectors sounds like they are dirty, if so i would get them cleaned, and you may want to flush out your fuel system do it with gas and feed from the engine(highest point) back |
Posted: Tue Feb 02, 2010 9:54 am Post subject: |
The tanks get rusty too. you might want to pull the intank pump and clean the pickup screen and see just what kind of crap is coming out of the opening on the bottem of the tank I had to remove mine and buy a reseal kit cause it was rusty and nasty.  _________________ 1979 porsche 924 Na
Have u ever driven a turbo. |
