Misfire Problems '77 924 Porsche
ajw0100
PostPosted: Thu Jan 14, 2010 1:14 pm    Post subject: Misfire Problems '77 924 Porsche Reply with quote
Hello Everyone, Any help at all would be greatly appreciated.
I am currently working on a 1977 Porsche 924.
Recent new parts include the following: battery, fuel pump, fuel filter, spark plugs, plug wires, cap and rotor, and the coil.
Additionally: the fuel tank was drained and filled with new gas; the fuel distributor, fuel lines and fuel injectors were cleaned.
The problem I am having is first the engine will only start with the cold start valve energized with a remote starter switch ran from the battery. (I understand this is common problem) However, if the injector is pulled out it does spray fuel with 10.5 volts from the harness connector but will not start without unhooking the connector and installing the remote switch. If the cold start valve is de-energized the engine immediately dies.
Next, the engine will start but is only running off of the #2 cylinder. After about 5 seconds of idling fuel starts to pour out of the exhaust. When the spark plugs are all pulled out #2 is clean and #'s 1, 3 and 4 are covered in fuel. Also, the exhaust tube for #2 is hot and #'s 1, 3 and 4 are cold.
Now, if I install an in-line spark tester all four wires will flash while cranking. And if the spark plugs are pulled out one at a time and grounded to the valve cover each will also fire while cranking.
Compression on four cylinders are equal and within specs. Valve timing and ignition timing are correct. Cooling system pressure test was okay. All plug wires are within resistance specs. Resistance on primary and secondary of coil are okay. Rotor and cap look good as well. The first set of new plugs we put in were champion then we tried a new set of NGK (Bosch was not available). The air valve moves freely and all injectors are spraying evenly.
So, I am not sure what is causing the misfires on 3 of the 4 cylinders.
It would be wonderful and anyone has some advice. Again, I would greatly appreciate it.
Joe
mikebola
PostPosted: Thu Jan 14, 2010 1:40 pm    Post subject: Reply with quote
Have you checked the spray pattern of the injectors? they may be leaking or have an obstruction.
proud owner of a 1979 924 Sebring Edition with a 931 trans that looks horrible but somehow runs...
Imafordguy
PostPosted: Thu Jan 14, 2010 2:02 pm    Post subject: Reply with quote
What color spark? Do you have good compression? Are you sure firing order is correct and correct direction or rotation?
With all new gear if your spark is weak... I would suspect wiring issuses.
81 Porsche 924
84 Porsche 944(parting it)
66 Ford f100
66 AC cobra kit car(major project)
64 ford f100 (429 SCJ)
62 Studebaker golden hawk gt
61 baja bug (with bad opel 1.8, looking at ford 2.3 turbo to flovo)
joejax
PostPosted: Fri Jan 15, 2010 1:29 pm    Post subject: Reply with quote
I would triple check to make sure timing is in line. also, thought I have heard on here that the wrong plug wires can be a problem.
Unsure about that, have not gotten a definate answer yet. Hopefully it's something that easy.
I got nothin'
Uhhh...you got any pics?
datatrain
PostPosted: Fri Jan 15, 2010 1:35 pm    Post subject: Reply with quote
I know this sounds simple, but I think your plug wires are on the wrong plugs.
'78 924 NA with Collector plate
Mint '92 318i BMW
Near mint '98 Buick LeSabre
VE7HFR
PostPosted: Fri Jan 15, 2010 10:15 pm    Post subject: Reply with quote
+1^
Make sure you have the plug wires on in the correct order AND the correct orientation. Order is 1-3-4-2, and the distributor rotates CLOCKWISE. If you installed them 1-3-4-2 counterclockwise, you will only fire on two cylinders.
Also, make sure your distributor is properly indexed.
ajw0100
PostPosted: Sat Jan 16, 2010 3:28 am    Post subject: Reply with quote
Compression is equal and within specs for all cylinders. I do have the firing order set up 1-3-4-2 with the rotor spinning clockwise. To set up the initial timing I put the #1 cylinder on TDC compression and turned the distributor cap so that the #1 spark plug wire is lined up with the rotor. This does get the engine to start but only on the #2 cylinder. Advancing or retarding the timing with it running doesn't make any difference. Also, removing the line to the vacuum advance and plugging the line on the manifold doesn't change anything. I printed off the article on indexing the distributor so I will check out how the marks are lined up and I will also check the color of the spark.
Thanks everyone for you help so far,
Joe
rkn
PostPosted: Sat Jan 16, 2010 4:13 am    Post subject: Reply with quote
Are your plugs getting flooded?
Last summer -after my car had been sitting for a while - I fitted new plugs and wires, and I could only get her fired up on 1-2 cyls., despite fuel/spark/timing being OK.
Turned out my A:F mix was way off and the the plugs practically drowned + fuel out the exhaust as you say.
How is your mixture? Perhaps your CSV is spraying non-stop?
1980 924NA ROW
poorsha924
PostPosted: Sat Jan 16, 2010 4:48 am    Post subject: mis fire 77 924 Reply with quote
Hi there (been there done that)
It could be several things no or low fuel volume, massive vaccum leak or other issuesThere is a few things you have to check 1st I see you live in KC so do I If you would like to contact me I could explain easier to talk to you then to type out thing you need to check. contact me thru the board via PM or my email address : bernieunlimited@aol.com
poorsha 924
79 924S snailshell
audi big bore t-body
16" turbo wheels
PostPosted: Sat Jan 16, 2010 5:23 am    Post subject: Reply with quote
Are you kidding fuel pours out of the exhaust are you sure its not water.
im thinking warm up regulator. though recheck plug wires. and make sure dizzy is indexed to proper firering order.. for firsts fuel pouring out the exhaust thats bad.
Slam
PostPosted: Sat Jan 16, 2010 5:56 am    Post subject: Reply with quote
As above re the spray pattern. Maybe three injectors are stuck open. Also control pressure check may give a clue. Keep an eye on your oil if you're flooding the crankcase with fuel. Bearings don't like that very much.
Welcome to the gang!
PostPosted: Sun Jan 17, 2010 5:49 pm    Post subject: Reply with quote
I know you checked your timing off TDC.
Did the cam line up at the same time?
The cam turns at 1/2 the speed of the crank and your timing could be 180 degrees off.
The crank AND cam have to line up at TDC to set the timing position for the rotor on no 1 cylinder.
PostPosted: Mon Jan 18, 2010 6:36 pm    Post subject: Reply with quote
how did you go?
PostPosted: Wed Jan 20, 2010 6:57 am    Post subject: Reply with quote
bump
924OZY
PostPosted: Sun Jan 24, 2010 11:00 pm    Post subject: I had the same problem Reply with quote
I had the same problem and thought it was running super rich on two cylinders after changing the plugs, and seeing two black ones.
Turns out the Leads were the wrong way around (counter clockwise 1342 by previous owner). Mine was rich on 1 and somethin else:
I Have to remove distibutor cap and check where the rotor button ends up at tdc, then do the leads as desribed above, then try to get a timing light on it and set the timing.
Good luck
924 N/A snailshell, superpro linkage bushes, 2.5"exhaust
4.0L ef Fairmont, 3000rpm stall, shift-kit, J3 chip, 3" exhaust, self tuned using tunerpro, soon to be boosted,
expecting 350Kw at wheels at 10psi.
