Oil Pressure Gauge Pegged Out Full
Andre'
PostPosted: Sun Sep 06, 2009 10:45 am    Post subject: Oil Pressure Gauge Pegged Out Full Reply with quote
Hi guys,
any advise on this one? Turned on the ignition after reinstalling A/C evaporator unit below the dash and replacing the dash with a new one, and the oil pressure gauge pegges out full. Bad sending unit? Bad gauge? The battery tray has been replaced - could it be the fact that the car has been welded on? How do I determine what's wrong here?
Thanks, and happy Labor Day to all!
Andre'
PostPosted: Sun Sep 06, 2009 11:14 am    Post subject: Reply with quote
You need to get a mechanical oil pressure gauge to test and see what the real oil pressure is.
Could be a gauge problem or could be an electcial problem you caused when you had the dash out.
This is the 924S Section, and if you really have a 924S, you could also have a sticking OPRV (oil pressure relief valve).
Do not start the engine or drive the car until after you have this problem diagnosed. A failed OPRV is a serious problem that could ruin your engine.
Andre'
PostPosted: Sun Sep 06, 2009 11:31 am    Post subject: Reply with quote
Thanks for the advice. It is a 924s, and everything was just fine before I took everything apart. Therefore, I believe its just some kind of electrical issue but I'm not sure. I do have a back-up gauge; I'll measure the voltage/amps to make sure I won't blow it for whatever reason. Do you happen to know the location of the sending unit?
Thanks!
PostPosted: Sun Sep 06, 2009 12:34 pm    Post subject: Reply with quote
Underneath the oil filter.
John_AZ
PostPosted: Mon Sep 07, 2009 9:23 am    Post subject: Reply with quote
When you replaced the dash, did you switch the wires on the dash guage?
Normally when someone installs the oil pressure sender on the engine and the wires are reversed--------------the dash needle pegs to 5.
GL
John_AZ
1988 924S + 1987 924S
Andre'
PostPosted: Mon Sep 07, 2009 1:24 pm    Post subject: Reply with quote
No - didn't switch the wires. Just unplugged the gauge and hooked back up during reassembly. I've already checked the wires - they connect correctly. I'll check the gauge tomorrow by installing in my back-up 924s.
Thanks for your help!
veewdriver
PostPosted: Thu Sep 10, 2009 4:21 pm    Post subject: Reply with quote
The "project" I just picked up does the same thing. I haven't started the car yet, but when I turn on the ignition, I get no oil warning light and the gauge pegs on 5 bar. Let me know what you find out, because it seems we have the same problem.
Tom in Tucson
Currently:
88 Red 944
81 Silver/Grey 924 Turbo
Past:
87 Black 924S
79 Red 924S (M471 options)
PostPosted: Thu Sep 10, 2009 8:28 pm    Post subject: Reply with quote
If the car isn't running and the oil pressure gauge pegs to 5, it can only be one of two things: either the wires have been reversed at one end or the other, or there is a ground fault in that circuit.
veewdriver
PostPosted: Fri Sep 11, 2009 2:37 am    Post subject: Reply with quote
Well, I was cleaning out the wheel wells in the back and I found on old, oily pressure sender. So you may be right, the wires may be switched. I'll check on it today and see if that fixes it.
Tom in Tucson
Currently:
88 Red 944
Past:
87 Black 924S
PostPosted: Fri Sep 11, 2009 9:22 am    Post subject: Reply with quote
A bad oil sender or gauge can also cause this. On the white ghost it was the sender.
Andre'
PostPosted: Sun Sep 13, 2009 11:17 am    Post subject: Reply with quote
The wires are definitively not switched! Just unplugged the gauge, swapped the dash, and reinstalled everything! The gauge is fine - I've checked the gauge in another 924s. I think the sender must be bad for whatever reason; I'll swap sending units to find out.
Thanks everybody!
Andre'
PostPosted: Sat Dec 26, 2009 8:34 am    Post subject: Reply with quote
Bad sender - problem fixed!
PostPosted: Sat Dec 26, 2009 8:46 am    Post subject: Reply with quote
Merry Christmas!
Andre'
PostPosted: Sat Dec 26, 2009 9:17 am    Post subject: Reply with quote
Thank you! Merry Christmas to you, too!
