polarity of hot start solenoid valve?
Duncan
PostPosted: Fri Jan 22, 2010 10:19 pm    Post subject: polarity of hot start solenoid valve? Reply with quote
I was wondering if the hot start solenoid valve (you know the one next to the fuel dizzy, only for >1979 models) has a specific polarity.
Is it important to put either of the red/orange or white/brownish wires at front or doesn't this matter at all?
I never thought about it because both contacts use the same type of
6 mm spade connector.
Duncan
1983 NA Alpineweiss since 2001
Peugeot 205 Generation
PostPosted: Sat Jan 23, 2010 7:43 am    Post subject: Reply with quote
Red usually is + and Brown is - so this may be a clue the way it goes
Duncan
PostPosted: Sat Jan 23, 2010 7:52 am    Post subject: Reply with quote
Thanks Ozzie,
I know the red/orange wire is + and the brown one is -, but there is nothing on the solenoid.
Duncan
PostPosted: Sat Jan 23, 2010 7:57 am    Post subject: Reply with quote
hook up to a battery and test but will probably be ok either way.
Duncan
PostPosted: Sat Jan 23, 2010 8:03 am    Post subject: Reply with quote
Yeah,
I was hoping someone who was certain of his properly working solenoid would take a peep.
