reilly525i
Joined: 07 Nov 2009 Posts: 222 Location: southern california
Posted: Fri Jan 08, 2010 5:07 am Post subject: removing the ignition distributor rotor sensor? |
ok. so I am going to need a fresh distributor but before I get my hands on one I would like to remove the rotor sensor to see if the sensor is visibly damaged. Ive noticed a smal soldering point that looks like its been clipped by one of the magnetic arms. theres a small lock pin on top and the flat head screw. both of which could be the securing principal in this. how do I remove the sensor properly without breaking it. Ive searched but to no avail. its an 80 n/a. Danka. rule # 1.
mine wants to look like this when it gets healthy. . _________________ "There are no kings inside the gates of Eden"
80 n/a 924.
76 alfa romeo spider
e34 525i.
xj6 vanden plas
vintage Sunbeam 6 speed bicycle |
Posted: Fri Jan 08, 2010 9:06 pm Post subject: |
You have to disassemble the entire distributor to get the sensor assembly out. The replacement cost of the sensor plus the labor is higher than the cost of buying a replacement distributor in many/most cases.
When the module in my 81 distributor fell apart at 100K miles, I took it a Bosch Authorized service center where it was disassembled and inspected, with the module replaced, and tested after reassembly. The labor was less than $50 at the time. I think the module was about $80-$100. |
reilly525i
Posted: Sat Jan 09, 2010 3:13 am Post subject: |
right on. looks like my inquisitive mind will have to wait. thanks _________________ "There are no kings inside the gates of Eden"
80 n/a 924.
e34 525i.
xj6 vanden plas
Posted: Sat Jan 09, 2010 3:19 am Post subject: |
I still have that rebuilt unit available...
...love the signal green, btw. Don't see too many in that color, it's a good color for the early cars. _________________ erstwhile owner of just about every 924 variant ever made |
