Brockoli
Joined: 06 Feb 2007 Posts: 621 Location: Edmonton, Alberta, Canada
Posted: Thu Dec 24, 2009 2:08 pm Post subject: Euro vs. US - What makes the extra 15HP? |
Why is there a difference in HP between the euro 924 and US/Canada 924? I think the euro has 9.3:1 pistons and less emissions stuff but that cant make 15HP, can it? Is it the camshaft or timing?
The reason I ask is that I plan on doing my rebuild in the summer and want to find some euro pistons. While I am in there what other euro parts can I use to get more power?
Also, how much does a euro car weigh? I know the toofah guru's on this board will probably know everything that is different  _________________ '80 924 M471,Wideband O2, Full coilover susp,23/19 sways,Bilstiens,KLA Strut Brace,Roll Bar,Test Pipe,BBS RS, Willwood BBK
'79 924 Sebring Edition(Sitting) |
xpernet
Joined: 07 Apr 2004 Posts: 414 Location: Kitchener, Ontario Canada
Posted: Thu Dec 24, 2009 2:36 pm Post subject: |
The North American cars came with a different distributor if im not mistaken... i didnt swap out a euro dizzy, but when i switched to EDIS i got a nice punch in power. Nothing big, but doesnt feel like a 95hp engine at all. _________________ 1977 Porsche 924
Sunroof Delete
Megasquirt II EFI & EDIS
Carrera GTS / 944 Body
"If one does not fail at times, then one has not challenged himself." Ferdinand Porsche |
!tom
Posted: Thu Dec 24, 2009 4:08 pm Post subject: |
I believe the big differences are distributor and pistons. Some US/Canada cars had smog pumps too which rob a bit of power.
My understanding is the pistons are the biggest difference. _________________ 78 924 NA
5-lug |
Scorpio
Posted: Thu Dec 24, 2009 4:47 pm Post subject: |
Power to weight...Dont Americans weigh more than Europeans?  _________________ 1979 NA
MS1..EFI..
GARRETT T25 TURBO
BILSTEIN SHOCKS
GT BASED CUSTOM BODYKIT
Brisbane , Australia
Think mean think fast
all youll see is
my Porsches Arse!!! |
Brockoli
Posted: Thu Dec 24, 2009 7:13 pm Post subject: |
xpernet - I think i might and source a euro dizzy but I bet the timing is different too. Something for me to look into...
!tom - i took off my EGR valve system. The only smog component left is the cat. which I will remove soon. I think the only cars with an air pump were the ones sold in california. Canada still isnt too strict on smog, alberta does have any smog testing
scopio - lol, I have already started a modest weight reduction. A/C, EGR system, sound deadening carpet in the back, spare tire. More to lose tho. _________________ '80 924 M471,Wideband O2, Full coilover susp,23/19 sways,Bilstiens,KLA Strut Brace,Roll Bar,Test Pipe,BBS RS, Willwood BBK
D Hook
Posted: Thu Dec 24, 2009 9:34 pm Post subject: |
| Scorpio wrote: | Power to weight...Dont Americans weigh more than Europeans?  |
Yes. That's because we carry quite a bit of dead weight.  _________________ '80 924 n/a SOLD |
PORSCHEV
Posted: Thu Dec 24, 2009 9:37 pm Post subject: |
It is the higher compression ratio and the lack of smog gear that gives the power. The euro dizzy is only good WITH the higher compression ratio. The euro dizzy just has more advance sooner with a different curve then the US spec.
PM me if you want a set of Euro Pistons for the standard bore. I have a set I will sell for $100.00 cdn. _________________ 1976 924
1978-#53 "D" track racer. |
Vince Ponz
Posted: Fri Dec 25, 2009 2:44 am Post subject: |
Weight is one problem. Here in the US we wanted more accessories. Air conditioning did not come standard in 1978 when I bought my car new. It was a very poor add on which did not work well.
Smog equipement would add weight, maybe the euro tranny was lighter, no sunroof=less weight, MUCH lighter front and rear bumpers and shocks[US total weight front and back about 48lbs vs 23lbs Euro] and stock wheel metal rims?? and thinner tires, wind up window equipement lighter than electric, smog parts, smaller rubber on the front bumpers [US 3lbs ea=6 lbs/Euro 8 ounces and some other items that I cannot think of.
Cam and pistons made up the difference also. _________________ "Never let them see you sweat"
77.5 924 modified track car
79 931 Euro stock
88 924S SE
87 911 Targa stock |
Harm
Posted: Fri Dec 25, 2009 6:01 am Post subject: Re: Euro vs. US - What makes the extra 15HP? |
Porsche 924 ('76-'85) Haynes (#397)
Info on page 4, short…
”From 1976 through 1977˝ model years, North American versions of the 924 had engines of 95 hp. This was a result of fitting low compression pistons and the addition of emission control systems. The emission controls which were used vary according to the sales market. (…
…) A redesign of the emission controls and the higher-compression pistons brought the engine output to 110 hp in the 1977˝ through 1979 models.
…) with the 1980 models. Changing the emission controls (…) and an additional raise in the compression ratio has lifted engine performance into the 120 hp range. Removal of pumps, valves and other emission control components has had the additional result of improved gas mileage figures.
Specifications for the European version of the 924 have remained nearly unchanged for the entire run of production. The engine produces 125 hp and is connected to a 4-speed, 5-speed, or optional automatic gearbox.
| !tom wrote: | | I believe the big differences are distributor and pistons. |
The only early distributor (95/110 hp) I knew of is the one mentioned in the early PET 76-79.
It states the early distributors (contact breaker type) is # E 047 905 205 B.
To my surprise I found some different numbers on AA, so you could/should be right about the different distributors !tom:
047 905 205 distributor for the XH, XF engine. XH=USA/Canada, XF=California/Japan : 1977.
047 905 205 X distributor for the XH, XF engine.
047 905 205 C distributor for the XG, XE engine. XG=USA, XE=California : 1978 - 79.
047 905 205 CX distributor for the XG, XE engine.
so it states there are different early engines on your continent carrying different distributors. Then why is there only one distributor number in the PET? …Odd.
BTW European engine codes are XK (=Europe, RoW) & XJ (=Europe, RoW-RHD)
| Brockoli wrote: | | Also, how much does a euro car weigh? |
My Toofah Vehicle Registration papers say it weighs 1070 Kilograms (2,358.95 US pounds?).
The only Haynes figure I could find is 1130 kg (1764 lb) for a standard Toofah '80+ (page 287).
And that 1130 kg is also what it says in my 1979 Porsche brochure. _________________ Porsche 924 NA 1982 LY7A/A3A3 _ Greater driving pleasure never harmed anyone. |
Posted: Fri Dec 25, 2009 6:25 am Post subject: |
Dish size in the top of the pistons and the dizzy. _________________ 1979 porsche 924 Na
Have u ever driven a turbo. |
CorsePerVita
Posted: Sun Dec 27, 2009 1:35 pm Post subject: |
i'm 135lbs of negative muscle mass. you just have to eat like a european to counter-act the american disease known as weight. _________________ - 1977 Porsche 924 2.0 N/A (Trackday Project)
- 1980 Porsche 931 (Daily)
- 1987 Lamborghini Jalpa
- 1999 Ducati 900SS |
Rich H
Posted: Sun Dec 27, 2009 8:42 pm Post subject: |
| CorsePerVita wrote: | | Scorpio wrote: | Power to weight...Dont Americans weigh more than Europeans?  |
i'm 135lbs of negative muscle mass. you just have to eat like a european to counter-act the american disease known as weight. |
I wouldn't recomend it - fries and mayonnaise is just wrong
We have plenty of tubbies here too anyway... _________________ 1994 Lotus Esprit S4 - Work in progress...
Slam
Posted: Wed Dec 30, 2009 5:59 am Post subject: |
All the above, plus the ignition advance. My Euro runs at 10 deg BTDC. The stock US cars are 3 deg ATDC in some cases! You'll also benefit from losing the cat and going with a pre-muffler. Dump the emissions junk. I actually would source a Euro dizzy for the difference in the advance curve. You'll notice it.
Back to back, Chrenan's old yellowjacket is faster at its top end than my Euro but the Euro is snappier. The yellowjacket actually feels like a less powerful version of my 944, which is saying a lot. _________________ '88 944 Auto - may or may not resurrect |
Brockoli
Posted: Thu Dec 31, 2009 3:08 pm Post subject: |
Slam - I have already got rid of the EGR valve, and I will eventually get rid of the cat. I am still on the fence about how far I want to go during my rebuild. The big valve head is always in the back of my mind... _________________ '80 924 M471,Wideband O2, Full coilover susp,23/19 sways,Bilstiens,KLA Strut Brace,Roll Bar,Test Pipe,BBS RS, Willwood BBK
!tom
Posted: Thu Dec 31, 2009 6:28 pm Post subject: |
| Brockoli wrote: | | The big valve head is always in the back of my mind... |
Likewise. _________________ 78 924 NA
5-lug |
