newman931
Joined: 25 Oct 2009 Posts: 30 Location: Tennessee, USA
Posted: Fri Jan 01, 2010 2:21 am Post subject: CRAZY idea for 924 - TURBO DIESEL! |
For a while I have tried to decide what to do with my 924 turbo.
Was going to make it original, then thought about a racer or a GT.
REALLY I want a reliable, HIGH gas mileage daily driver.
I'm really not sure if this will work...
The 931 motor was made by vw/audi, correct?
So, wouldn't an older VW turbo diesel motor work with the existing transmission? Of course with some mounting and electric modification.
What kind of bell housing fit would have to happen?
Any thoughts??????
Also, I'm gonna part out my 931 engine or sell the whole thing, so if any needs/wants any really good parts or the whole engine, let me know. |
9xx
Joined: 18 Jun 2006 Posts: 627 Location: Jarvenpaa, Finland
Posted: Fri Jan 01, 2010 2:43 am Post subject: Re: CRAZY idea for 924 - TURBO DIESEL! |
| newman931 wrote: | The 931 motor was made by vw/audi, correct?
No, they were hand made in Zuffenhausen by Porsche. _________________ Mikko
All gone: 931 '82 Alpine White, original option "220" G31 with LSD + 3 x 944 |
Posted: Fri Jan 01, 2010 4:14 am Post subject: |
Wasn't the same block used in the Diesel Vanagons? _________________ Stefan
Posted: Fri Jan 01, 2010 4:33 am Post subject: |
The 2.0L block is in fact the same block used for the diesel VW LT trucks. Not sure if that's the same thing as the Vanagon, thought those were a bit later and a different power plant... _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Fri Jan 01, 2010 5:34 am Post subject: |
i'm sure you could swap in a 1.9 TDI 150HP Audi unit.
would take alot of work but its doable. _________________ Supercharger and EFI kits
bnoon
Joined: 12 Oct 2009 Posts: 607 Location: West Des Moines, IA USA
Posted: Fri Jan 01, 2010 6:57 am Post subject: |
TDI would be the shiz, TD would still rock... then do a bio conversion to run used veggie juice. Ummmmmmm, the smell of french fries. _________________ '80 924 Turbo - SOLD!
Porscheless  |
PORSCHEV
Posted: Fri Jan 01, 2010 12:09 pm Post subject: |
I run veggie in my F250...it does NOT smell like french fries It smells like a BBQ!
BTW an audi diesel has been done if you search the conversion section. _________________ 1976 924
1978-#53 "D" track racer. |
Martijnus
Joined: 29 Dec 2006 Posts: 2019 Location: Netherlands
Posted: Sat Jan 02, 2010 3:01 am Post subject: |
| ideola wrote: | | The 2.0L block is in fact the same block used for the diesel VW LT trucks. Not sure if that's the same thing as the Vanagon, thought those were a bit later and a different power plant... |
euh.. I'm not really sure... but those engines were petrol engines.
The diesel LT had a quite different engine.
but again, not 100% sure. _________________ "Rule: Turbo's make torque, and torque makes fun." (C. Bell)
924 "50-jahre", 1981.
MSII/extra, LPG, ITB's, 5lug.
To be turbo'ed in a while.
Killed her at the Nurburgring, Porscheless at the moment |
924guy
Posted: Sat Jan 02, 2010 3:25 am Post subject: |
a 931 in good repair should get you at least 28mpg hwy, and if you go easy, better than 30mpg is generally no problem, which is pretty darngood for a car thats 30 years old...
Ive gotten better than 35mpg in my n/a 2.0.
our new rabbit 5cyl doesnt even do 30 mpg consistently... _________________ Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
Performance by Pasha |
gegge
Posted: Sat Jan 02, 2010 3:37 am Post subject: |
http://www.924board.org/viewtopic.php?t=24994
http://www.924board.org/viewtopic.php?t=12366
1990s to 2000 D5252T 2460cc Audi TDI 5 cylinder in Volvo 850 and S70/V70 and early S80s. 2.5TDI is just a 1.9TDI with additional cylinder. _________________ Carl Fredrik Torkildsen
moone924
Joined: 05 Feb 2003 Posts: 869 Location: Douglas Wyoming
Posted: Sat Jan 02, 2010 1:30 pm Post subject: |
| gegge wrote: | http://www.924board.org/viewtopic.php?t=24994
1990s to 2000 D5252T 2460cc Audi TDI 5 cylinder in Volvo 850 and S70/V70 and early S80s. 2.5TDI is just a 1.9TDI with additional cylinder. |
The 5 cylinder TDI has a Audi style bellhousing bolt pattern, like our 924's, the 1.9TDI is like a 4 cylinder VW engine, total different pattern, and also different from early and late motors. _________________ Ryan Moone
Always shopping for a nice s2 931 to baby.
New philosophy : one car project at a time. |
gegge
Posted: Sat Jan 02, 2010 7:45 pm Post subject: |
| moone924 wrote: | | gegge wrote: | http://www.924board.org/viewtopic.php?t=24994
The 5 cylinder TDI has a Audi style bellhousing bolt pattern, like our 924's, the 1.9TDI is like a 4 cylinder VW engine, total different pattern, and also different from early and late motors. |
That is why you should use the Audi 1.9TDI (longitudinally orientated engine at the front)
Frankly, I donīt know the bolt pattern of the Audi engines. But if you are going throu the trouble fitting another engine an adapterplate doesnīt compicate things that much. _________________ Carl Fredrik Torkildsen
moone924
Posted: Tue Jan 05, 2010 10:56 am Post subject: |
| gegge wrote: | | moone924 wrote: | | gegge wrote: | http://www.924board.org/viewtopic.php?t=24994
Frankly, I donīt know the bolt pattern of the Audi engines. But if you are going throu the trouble fitting another engine an adapterplate doesnīt compicate things that much. |
Gegge - The later Audi (also VW Passat) TDI longitudinally mount transaxles are dual pattern, with Audi and VW patterns - Transaxles based on the 01A or 01E.
Yes, if you're going to do a swap you might as well build a adaptor plate. But I always want to find the bolt in solution. _________________ Ryan Moone
