need some injectors
masterdave
PostPosted: Wed Dec 09, 2009 2:07 pm    Post subject: need some injectors Reply with quote
my fuel injectors seem to not be working, dcauto will sell replacement ones for 30$ but they are use does any one know of a cheaper place, or have some ones they are willing to part with.
joecitizennn
PostPosted: Thu Dec 10, 2009 3:24 am    Post subject: Reply with quote
have you tried cleaning yours? They can be cleaned. YOu can buy a kit off the internet that contains the upper screen, o-rings and tip cap. Napa carries a kit that contains just the tip cap and o rings but not the screen. I used carb cleaner to clean mine out, tapping them up side down on a block of wood to clear the gunk out of the upper screen.
it seems unlikely for all injectors to go bad at once and need total replacement.
masterdave
PostPosted: Thu Dec 10, 2009 4:59 am    Post subject: Reply with quote
yeah i cleaned them and replaced the O rings when the problem started happening. I dont think they are all bad. if i remember correctly #1 is defiantly bad and i think 2 or 3 is intermittent. But the car wont even start up any more, for a while i could get it started but now it wont even catch.
moorepower
PostPosted: Thu Dec 10, 2009 9:02 am    Post subject: Reply with quote
Send them here: http://www.southbayfuelinjectors.com/servtree--.html
For $15 apiece they'll clean, thoroughly test, replace all screens and seals, flow match, etc, etc. They'll basically be like new.
I've used them before with good results.
Dan.
'88 924S-LE (Luddite Edition)
Manual steering, manual sunroof, manual windows, AC delete, cruise delete, M030 Konis, 25.5mm torsions, 26.8/20 sways
John_AZ
PostPosted: Thu Dec 10, 2009 10:50 am    Post subject: Reply with quote
My memory is short and if I replied to this topic previously, ignor me.
Possible solution in link:
http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/457608-cleaning-injectors-advice.html
GL
John_AZ
1988 924S 60K+ 1987 924S 114K
joecitizennn
PostPosted: Fri Dec 11, 2009 4:21 am    Post subject: Reply with quote
have you checked your fuel pressure and your fuel pump volume capacity with specs?
masterdave
PostPosted: Fri Dec 11, 2009 4:14 pm    Post subject: Reply with quote
yeah the pressure was fine, at first i though that was the issue so i replaced the check valve and all the fuel lines around the pump, ill retest when i get home on sunday but as far as i remember it was not the issue.
