Fuel Pump help
HEMBRANT12
PostPosted: Wed Dec 16, 2009 4:12 pm    Post subject: Fuel Pump help Reply with quote
I have 88 924S. When the weather is above freezing the car will start on the first crank and when I turn the ignition I can hear the pump fire right up. When the weather gets cold the fuel pump won't kick in. I turn the ignition and I cant hear the pump start at all. I don't think the pump is shot or it would'nt work most of the time? What do ya'll think it could be? The fuel pump relay? Any help is appreciated.
Thanks!
1988 Porsche 924S
1970 VW Karmann Ghia
1971 VW Super Beetle
2007 VW Rabbit
masterdave
PostPosted: Thu Dec 17, 2009 8:58 am    Post subject: Reply with quote
fuel pump relay is always a good place to start if thats the issue its a cheap fix and worth replacing. You can test the pump by disconnecting the bat first jumping terminals 30 and 87b with a wire, then remove the bolt at the head of the fuel rail run some hose off of it to a bucket, reconnect the bat, turn the key and the pump should kick in you may not even need to turn the key i dont remember but the pump should give you 850cc every 30 sec.
