Passenger side carpet mold
dash16
PostPosted: Fri Dec 04, 2009 6:55 am    Post subject: Passenger side carpet mold Reply with quote
Just found mold accumulating on the carpet on the passenger side in front, underneath, and behind the seat.
What are the common leakage areas to the passenger cell of these cars?
I want to seal up this bad boy for good.
1987 Porsche 924S Black/Black. 5-spd.
Options: AFX C79 261 398 423 650 651 657
1987 Mercedes 190E 2.3-16 Cosworth Pearl Black/Black. 5-spd.
STUTTGART PREVAILS
moorepower
PostPosted: Sat Dec 05, 2009 6:35 am    Post subject: Reply with quote
Most likely battery tray. All three of the 924's I've had leaked there.
Dan.
'88 924S-LE (Luddite Edition)
Manual steering, manual sunroof, manual windows, AC delete, cruise delete, M030 Konis, 25.5mm torsions, 26.8/20 sways
PostPosted: Sat Dec 05, 2009 6:44 am    Post subject: Reply with quote
As Dan notes, the battery tray is suspect number 1, followed closely by a clogged rear passenger side sunroof drain, both sunroof seals, the upper door seals themselves, the little known drain tube behind the steering wheel that pass from behind the wiper motor into the cockpit and back through the firewall, and finally, the tee at the rear sunroof drain tube by the gas filler neck which if clogged or disconnected will leak behind the inner quarter liner and onto the rear passenger side floor.
Not bad for one sentence, eh?!
