Switch speedometer and tach location
gla924sem
PostPosted: Fri May 21, 2010 6:57 pm    Post subject: Switch speedometer and tach location Reply with quote
Would rather see the tach in the center of the instrument cluster than the speedometer.
Makes more sense as I race/track the car
Anyone do this??? Any issues in doing???
First look......seems like its possible
PostPosted: Fri May 21, 2010 8:27 pm    Post subject: Reply with quote
Gary, absolutely doable. The biggest issue in doing it is to make sure you have sufficient slack in the speedometer cable. It might require you to re-route it in the engine bay, and then push it further into the cockpit, but it is definitely doable.
PostPosted: Sat May 22, 2010 12:44 am    Post subject: Reply with quote
Done this, the key was to unhook the bunch of electrical cables that were in the way and just put them som cm away. The biggest problem here is the angle on the cable (speedo), the wire needs to be curved very carefully or you will have problems with a not so smooth speedo afterwards. The hardest thing is that there is some metal in the way for the cable, but the cable can be moved so it will be acceptable.
PostPosted: Sat May 22, 2010 3:56 am    Post subject: Reply with quote
mmmmm, early turbo green gauges, nice.
Mine is the same, only diffy is that I turned the tacho about 90 degrees CW so redline is straight up. That way I don't actually have to look to know I'm at (or over ) redline.
PostPosted: Sat May 22, 2010 10:35 pm    Post subject: Reply with quote
Moved mine around a couple of weekends ago. Also re covered the gearshift with black suede leather to match the Momo wheel.
smart931
PostPosted: Sun May 23, 2010 3:19 am    Post subject: Reply with quote
My car was like this when i bought it. I switched it back.
I really like the choice of steering wheels in those pics.
1982 Porsche 931 (Sold)
2000 Smart Fortwo (Waiting for import)
1972 Opel manta (Left in England)
1965 Chevrolet Corvair (Left in England)
2010 Mazda 3 (Ex got this in divorce)
1974 Triumph TR6 (sadly gone)
1968 Ford F250 Camper Special (Daily)
PostPosted: Sun May 23, 2010 4:26 am    Post subject: Reply with quote
Mr. RSR, what boost gauge is that? Looks really nice with the 931 green gauges...
thirdgenbird
PostPosted: Sun May 23, 2010 2:16 pm    Post subject: Reply with quote
i did both of these mods too.
steering wheel:
tach mod:
17in caymans, koni yellow coilovers, hypercoil springs, kla solid upper mounts, 968 sway bars, kla drop links, kla strut brace, fidanza flywheel, dansk catback, wilwood front calipers, ss brake lines, e-codes, 944 duckbill, manual rack,momo steering wheel
PostPosted: Sun May 23, 2010 8:22 pm    Post subject: Reply with quote
Its a boost gauge by TIM. Just needed some additional green marker pen on the white numbers and some orange paint on the needle. Ideally would like a custom vdo 1.5 bar gauge done to match in perfectly.
