Regrind lifters?
Fifty50Plus
PostPosted: Tue Feb 28, 2012 2:03 am    Post subject: Regrind lifters? Reply with quote
I've found a machinist who regrinds Porsche 356 and air cooled VW lifters. He puts a .001 in. taper on them for reuse in engine rebuilds with new cams. Does anyone have an idea as to whether 924 lifters can be reused if this is done to them?
Chuck
1982 924 NA race car - Sold
1981 924 Turbo sold
1982 924 Turbo sold
PostPosted: Tue Feb 28, 2012 3:30 am    Post subject: Reply with quote
There was some considerable discussion on this topic a ways back. Something about grinding off the "hardened" layer on the surface of the lifter. Not sure whether we ever came to a fact-based definitive conclusion but IIRC, it was "buy new lifters"...
That being said, I've reused lifters without having problems as long as they don't have any discernable wear, gouging or pitting on the flat surface. Others will have opinions on this but that's my personal experience...
PostPosted: Tue Feb 28, 2012 3:53 am    Post subject: Reply with quote
My two cents on this: I went new because I had just dropped a ton of coin on a cam, and the warranty required new lifters.
daniel
PostPosted: Tue Feb 28, 2012 9:35 am    Post subject: Reply with quote
I have just done a season and a half of racing on a cam that had reground lifters. No visable wear and no need to adjust clearences.
Go for it
1989 944 Cabriolet
mikebola
PostPosted: Tue Feb 28, 2012 9:53 am    Post subject: Reply with quote
what are the requirements for the cores, and how much do they charge? to they do anything to harden or treat the bearing surfaces?
proud owner of a 1979 924 Sebring Edition with a 931 trans that looks horrible but somehow runs...
daniel
PostPosted: Tue Feb 28, 2012 2:43 pm    Post subject: Reply with quote
I have had two sets done, I beleive they only grind them no hardening. Regarding cost I have no idea as it was part of a bigger job on both occasions but most places charge in the order of $10 ~ $15 per lifter
1989 944 Cabriolet
PostPosted: Tue Feb 28, 2012 11:06 pm    Post subject: Reply with quote
I seem to recall a suggestion that they should be hard chromed after grinding.
Let me see if we can get our resident machining expert to weigh in...
Julian
PostPosted: Thu Mar 01, 2012 8:27 pm    Post subject: Reply with quote
My valve grinder is set up to reface lifters. Never get requests to do, it so I've only done my own
