Clutch cable ends
datatrain
PostPosted: Sat Oct 10, 2009 8:22 am    Post subject: Clutch cable ends Reply with quote
Where ? Oh where can I buy the cable ends. Autohaus AZ has the cable but they come without ends.
'78 924 NA with Collector plate
Mint '92 318i BMW
Near mint '98 Buick LeSabre
VE7HFR
Jakkq
PostPosted: Sat Oct 10, 2009 8:25 am    Post subject: Reply with quote
I provided you with a link for metal ones in the previous thread post.
http://www.automotion.com/product.asp?pf_id=P904531&dept_id=5058
1979 Porsche 924- Snailshell
http://porsche924workblog.blogspot.com/
datatrain
PostPosted: Sat Oct 10, 2009 8:30 am    Post subject: Reply with quote
I know, but the picture is not what I need. I need the fork that screws on the cable end and attaches to the pedal. The pic did not look like that. They don't list one for a 78 924
Mint '92 318i BMW
VE7HFR
PostPosted: Sat Oct 10, 2009 9:27 am    Post subject: Reply with quote
http://www.midwestcontrol.com/catdisplay_short.php?pg=215
I think the thread on the end of the cable is 6mm, just find one with an opening that will clear the arm and add an appropriate sized pin.
datatrain
PostPosted: Sat Oct 10, 2009 9:32 am    Post subject: Reply with quote
Thank you.... now I'll be able to sleep tonight. I knew there had to be a source out there somewhere.
Mint '92 318i BMW
VE7HFR
Octane
PostPosted: Sat Oct 10, 2009 10:09 am    Post subject: Reply with quote
I have access to a ton of those at work (for a different application) that look identical, with the same locking clips and everything. They have M6 threads, let me know if anyone needs some.
- Brendan
1977 Porsche 924
datatrain
PostPosted: Sat Oct 10, 2009 1:00 pm    Post subject: Reply with quote
Thanx, I'll need to get the end off over the weekend and can let you know the size I need.
Mint '92 318i BMW
VE7HFR
datatrain
PostPosted: Sun Oct 11, 2009 6:39 am    Post subject: Reply with quote
One slight error in drawing.... the threaded hole goes all the way through.
Here are the dimensions of the cable end required. How do I contact you
Mint '92 318i BMW
VE7HFR
datatrain
PostPosted: Fri Oct 16, 2009 7:13 am    Post subject: Reply with quote
This looks like the right part and it's $13.00 the downside is the shipping and handling is a whopping $28.00
But if you gotta have it you pay !
The MTC-6L-ss has all the correct dimensions. The pin with clip is SP6ML-ZC
Hope it arrives before the plate expires for the winter.
Mint '92 318i BMW
VE7HFR
