datatrain
Joined: 15 Sep 2007 Posts: 441 Location: Osoyoos, British Columbia
Posted: Sat Oct 10, 2009 8:22 am Post subject: Clutch cable ends |
Where ? Oh where can I buy the cable ends. Autohaus AZ has the cable but they come without ends. _________________ '78 924 NA with Collector plate
Mint '92 318i BMW
Near mint '98 Buick LeSabre
VE7HFR |
Jakkq
Joined: 29 Sep 2008 Posts: 810 Location: Omaha, Nebraska
datatrain
Posted: Sat Oct 10, 2009 8:30 am Post subject: |
I know, but the picture is not what I need. I need the fork that screws on the cable end and attaches to the pedal. The pic did not look like that. They don't list one for a 78 924 _________________ '78 924 NA with Collector plate
Mint '92 318i BMW
VE7HFR |
Posted: Sat Oct 10, 2009 9:27 am Post subject: |
http://www.midwestcontrol.com/catdisplay_short.php?pg=215
I think the thread on the end of the cable is 6mm, just find one with an opening that will clear the arm and add an appropriate sized pin. _________________ Stefan
datatrain
Posted: Sat Oct 10, 2009 9:32 am Post subject: |
Thank you.... now I'll be able to sleep tonight. I knew there had to be a source out there somewhere. _________________ '78 924 NA with Collector plate
Mint '92 318i BMW
VE7HFR |
Octane
Joined: 30 Jun 2009 Posts: 100 Location: Hamilton, Ontario, Canada
Posted: Sat Oct 10, 2009 10:09 am Post subject: |
I have access to a ton of those at work (for a different application) that look identical, with the same locking clips and everything. They have M6 threads, let me know if anyone needs some. _________________ - Brendan
1977 Porsche 924 |
datatrain
Posted: Sat Oct 10, 2009 1:00 pm Post subject: |
Thanx, I'll need to get the end off over the weekend and can let you know the size I need. _________________ '78 924 NA with Collector plate
Mint '92 318i BMW
VE7HFR |
datatrain
Posted: Sun Oct 11, 2009 6:39 am Post subject: |
One slight error in drawing.... the threaded hole goes all the way through.
Here are the dimensions of the cable end required. How do I contact you _________________ '78 924 NA with Collector plate
Mint '92 318i BMW
VE7HFR |
datatrain
Posted: Fri Oct 16, 2009 7:13 am Post subject: |
This looks like the right part and it's $13.00 the downside is the shipping and handling is a whopping $28.00
But if you gotta have it you pay !
The MTC-6L-ss has all the correct dimensions. The pin with clip is SP6ML-ZC
Hope it arrives before the plate expires for the winter. _________________ '78 924 NA with Collector plate
Mint '92 318i BMW
VE7HFR |
