How to remove ignition switch?
brealytrent
PostPosted: Tue Sep 01, 2009 12:45 pm    Post subject: How to remove ignition switch? Reply with quote
Ok, I have figured out that the ignition switch (behind the key) needs to be replaced. Don't worry, I made sure this is the problem and not the starter or solenoid. Now, how do you remove it? The Haynes manual doesn't say anything about it. Thanks!
PostPosted: Tue Sep 01, 2009 12:52 pm    Post subject: Reply with quote
This procedure for a 944 is close enough....
http://clarks-garage.com/shop-manual/elect-25.htm
PostPosted: Tue Sep 01, 2009 9:45 pm    Post subject: Reply with quote
http://www.924.org/techsection/12body.htm#2%20-%20Ignition%20Lock%20Removal/Replacement
