External Fuel Pump
oldmanwintersret
PostPosted: Mon Aug 31, 2009 3:00 am    Post subject: External Fuel Pump Reply with quote
I have an 1982 924 NA. Some kind hearted fool installed a rubber fuel line between the banjo bolt and the check valve. Splicing two male ends together. Am I correct in assuming the banjo bolt is just a "cap" and I could take the male end out of it? To me as outlined in http://www.924board.org/viewtopic.php?t=15721 item 10b it appears so. What is the best way to take it apart?
