034 motorsports vr6 adapter...
beario
PostPosted: Mon Aug 17, 2009 6:59 am    Post subject: 034 motorsports vr6 adapter... Reply with quote
so everyone tsaliking about the 034 adapter plate for the vr6 to o16 audi bellhousing...has any one actually used this and is the porsche 016 b/housing the same as the audi 016...because its an expensive excersize if they are not the same...
theres no replacment for displacement....V8
PostPosted: Wed Aug 19, 2009 12:58 pm    Post subject: Reply with quote
Yes, they are the same.
You'll need to use a 924 N/A or 924 Turbo bellhousing as the 944 uses a different bellhousing on the engine side (the other end of the torque tube is a reversed Audi bellhousing)
Keep in mind that the reason that many don't run other Audi-style engines in these cars is due to a lack of space around the strut towers caused by the angle of the engine. So the cross flow headed engines tend to work better.
A VR6 is wider I believe, so you may have to watch that as you move forward on this.
Good luck
