joecitizennn
Posted: Sat Nov 28, 2009 2:44 pm Post subject: Hesitation on accel |
| Relatively new problem here. Just noticed the last two times I drove my 1988 S that it would from time to time hesitate on accelleration. It would cruise fine, and do very hard accelleration fine, but light pressure to the throttle would cause the engine to hesitate. Any thoughts? |
9xx
Posted: Sun Nov 29, 2009 10:11 pm Post subject: |
How about air flow meter? The moving arm inside it on the film like surface. As you might know that surface deteriorates over time and then causes hesitation. But this was only a wild guess. _________________ Mikko
joecitizennn
Posted: Mon Nov 30, 2009 3:08 am Post subject: |
| a wild guess is what i wanted. I was thinking MAF but have never had this problem before. I will see if the arm has cut through the film surface. If it has I will shorted it to a diffirent track. |
Posted: Mon Nov 30, 2009 3:12 am Post subject: |
Check for vacuum leaks and check your TPS to make sure it's not telling the DME that the throttle is still shut. _________________ White 87 924S "Ghost"
joecitizennn
Posted: Mon Nov 30, 2009 3:41 am Post subject: |
already checked for vacuum leaks. Recently replaced this.
I bet there is a groove worn in my tps. |
bcblase
Posted: Sat Dec 05, 2009 2:54 am Post subject: |
Ditto on Paul's comments - TPS and MAF check is in order.
Brad _________________ 1987 Porsche 924S - track toy
joecitizennn
Posted: Sun Dec 06, 2009 8:40 am Post subject: |
| fixed problem last week. it was the MAF. Car now getting a steady 24MPG! |
Browar
Joined: 02 Jan 2003 Posts: 90 Location: Warsaw,Poland
Posted: Sat Dec 19, 2009 10:03 pm Post subject: |
Good You found the problem. Last time I had hessitation it turned out it was bad ignition wires. _________________ Browar
eS
924 S `87 |
