(Ultimate) Hypothetical Dash Reconstruction Solutions...
flosho
PostPosted: Thu Sep 16, 2010 4:17 am    Post subject: (Ultimate) Hypothetical Dash Reconstruction Solutions... Reply with quote
If you were going to DIY your own dash, what method have you, or would you do. What products would you use?
For example:
Strip off the cracked dash material, lay down some expanding poly foam, sand, and layer bed liner, then sand smooth and reapply?
Or maybe instead of roll on bedliner, try to stretch some sort of fabric across the dash?
My dash is out, and I'm going to attempt to recover it in some way shape or form. I know there are a lot of attempts (and successful ones at that!) but I'd like to gather all the solutions into one thread. The more detail the better. Also pictures are a benefit!
[This Space For Rent]
PostPosted: Thu Sep 16, 2010 7:14 am    Post subject: Reply with quote
Uploaded with ImageShack.us
3M Di-Noc for that carbon fibre look.
PostPosted: Thu Sep 16, 2010 7:41 am    Post subject: Reply with quote
As an alternative to the spray can expanding foam - could go with Gorilla glue, or an equivalent polyurethane glue from another maker.
Dribble it into the cracks and watch it foam up as it dries (if you have nothing better to do).
Rattlinbone
PostPosted: Fri Sep 17, 2010 4:27 am    Post subject: Reply with quote
I've seen several examples of dashes that have been sanded, filled with expanding poly foam, sanded again and then covered with leather or vinyl. I really like that look.
I'm not too crazy about the carbon fiber look on 924 dashes. I mean, it looks cool, but I don't think it looks appropriate on a car as old as a '79 924. Personally, I'd rather go with something that looks period correct.
YMMV
Fred- 1979 924
PostPosted: Fri Sep 17, 2010 6:04 am    Post subject: Reply with quote
Ihy on the leather looks quite swank donut. Cheers.
Rattlinbone
PostPosted: Fri Sep 17, 2010 8:52 am    Post subject: Reply with quote
ihy?
Fred- 1979 924
flosho
PostPosted: Fri Sep 17, 2010 9:26 am    Post subject: Reply with quote
So do u tear the old vinyl off the dash or start sanding the original dash surface?
PostPosted: Fri Sep 17, 2010 10:27 pm    Post subject: Reply with quote
Start sanding the original dash surface.
PostPosted: Sat Sep 18, 2010 3:30 am    Post subject: Reply with quote
Yea by diving in an jus starting sanding start rough then switch to a finer grit and youll get a smooth surface, you can even feather the plastic skin into the foam.
Min
PostPosted: Sun Sep 19, 2010 5:53 am    Post subject: Re: (Ultimate) Hypothetical Dash Reconstruction Solutions... Reply with quote
A complete new one formed to the original shape out of 1/16th aluminum.
Min
924guy
PostPosted: Sun Oct 03, 2010 11:01 am    Post subject: Reply with quote
Ive been pondering the same thing... no answers yet, just pondering the question...
Though using a large truck rubber inner tube has occurred to me....
Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
Performance by Pasha
