brake disks going bad?
PostPosted: Wed Apr 08, 2009 6:12 am    Post subject: brake disks going bad? Reply with quote
what can cause brand new brakedisks to develop complete wall offset on certain areas?
i've noticed that at higher speeds the steering wheel wobbles a bit (over 170-180) kept driving it and now it has become worse and i checked into the problem.
i checked the rims and they are spotless. rubber is not new nor perfect....but think that bad tires alone cannot make the brake disks offset areas...or would they?
Rich H
PostPosted: Wed Apr 08, 2009 6:24 am    Post subject: Reply with quote
What is wall offset?
PostPosted: Wed Apr 08, 2009 6:53 am    Post subject: Reply with quote
Typically, incorrect brake pad bedding procedures. Rarely to rotors "warp" Brake material was not distributed evenly on the rotor faces, this leads to pulsation under braking or just coasting. Following proper brake pad bedding procedures will help.
If you are seeing a lot of wear on the rotors, change the rotors and change the pads to a less aggressive compound. Some of the "racing" brake pads are fairly abusive to brake rotors and if you run "cheap" rotors they may wear even faster.
Read these:
http://www.ffcobra.com/FAQ/brakes3.html
http://www.scirocco.org/faq/brakes/pulpfriction/pfpage1.html
http://grassrootsmotorsports.com/forum/grm/bedding-in-new-brakes/4099/page1/
http://www.afcoracing.com/tech_pages/brake_prob.shtml
http://grassrootsmotorsports.com/forum/grm/brake-question/8989/page1/
Good Luck!
PostPosted: Wed Apr 08, 2009 7:13 am    Post subject: Reply with quote
offset means this:
perhaps a better drawing is this:
Pads are not race but normal road use units...disks are not worn at all...just bended.
I never overheated the disks and then went trough wather with them or forced them to cool down in any way.
i bled the system using the right procedure..brake works very good...well except in wobbles the steering wheel.
i'm thinking this could be caused by some mechanical wear in the spindle..bearing..? tho there is no play at all...the car i have swapped the spindles from had the same problem...bended disks..i also took the disks and then realised they are bended..had them changed with new zimmermans and now these got bended.
the donor car had different wheels and tires so i think i can rule out the fact that the tires caused this.
PostPosted: Wed Apr 08, 2009 7:16 am    Post subject: Reply with quote
Bad/misadjusted wheel bearings?
Fifty50Plus
PostPosted: Wed Apr 08, 2009 7:19 am    Post subject: Reply with quote
Several hard stops that heat the rotors and then keeping your foot on the brake pedal (e.g. at a long stoplight) may cause warpage.
Regards,
Chuck
PostPosted: Wed Apr 08, 2009 7:31 am    Post subject: Reply with quote
+1
Wobbling only while braking means warped rotors.
Resurfacing might be an option if they can be made straight again without exceeding the minimum thickness spec. (Going thinner than the min. thickness will leave you with too-skinny rotors that will re-warp very quickly.)
Mine had developed quite a wobble on high speed braking about a year ago. I put on new front discs made by Zimmerman in Germany (pretty good pricing). As predicted that fixed that problem right up.
PostPosted: Wed Apr 08, 2009 10:14 am    Post subject: Reply with quote
Do you torque your lugnuts to spec with a torque wrench? I do.
-But I also do not often (never) find myself braking hard from 180kph..
Scorpio
PostPosted: Wed Apr 08, 2009 10:38 am    Post subject: Reply with quote
The mitsubishi magna (front wheel drive) had the same problem...no wobble/shaking till about 100km up..then very bad but only every so often....when brakes were hit once wobbling started it would shake the whole car violently
new rotors (turned out cheaper for me to buy new ones then to have them machined..go figure)...new pads....no more problem...still some squeeking though
1979 NA
MS1..EFI..
GARRETT T25 TURBO
BILSTEIN SHOCKS
GT BASED CUSTOM BODYKIT
Brisbane , Australia
Think mean think fast
all youll see is
my Porsches Arse!!!
PostPosted: Wed Apr 08, 2009 3:41 pm    Post subject: Reply with quote
guys....the bended rotors are NEW zimmermans...i've mounted them last year in autumn and did max 1000Kms since then. Log nuts are tight no prob. I've replaced the old rotors because they were bended too..
rims are tight,rubber is bad...but rubber alone cannot make the rotors bend/wrap.
the steering wheel shakes when i go over 40mph and it shakes the whole car when i brake...the rotors are causing this...i've had this before...replaced the rotors and that fixed the problem...now it's back !
PostPosted: Wed Apr 08, 2009 5:05 pm    Post subject: Reply with quote
have you rebuilt the calipers?
It is possible that the calipers are dragging some and not allowing proper disappation of heat. As well you need to brake hard and fast, dragging the brakes builds up far more heat far faster.
3 928s,
PostPosted: Wed Apr 08, 2009 6:37 pm    Post subject: Reply with quote
The idea behind using a torque wrench is not just to get them tight, but more importantly to get them all the same tightness. (For even clamping force and even heat dissipation.)
Your problem may lie somewhere with that, braking habits as mentioned, brakes dragging / poor heat dissipation, bent rims...
Another possible scenario - alignment and/or other suspension problems (worn bushings, wheel balance, etc) causing a wobble while off the brakes, may be contributing to poor pad bedding-in that's resulted in worsening braking wobble. In this situation, (un-even bedding-in, not actually warpage) it may be possible to improve/eliminate the brake wobble by roughing-up the rotors with sandpaper (if done carefully/evenly all the way around and on both sides). -But obviously you'd still need to correct the non-braking wobble as well.
PostPosted: Wed Apr 08, 2009 6:46 pm    Post subject: Reply with quote
yea...thanks for the ideeas....the thing is that everything seems perfect...rims are perfectly straight, balanged and all that...bearings have no play and make no noise...alignment is spot on...disks were new..pads in very good condition(almost new)
PostPosted: Wed Apr 08, 2009 7:08 pm    Post subject: Reply with quote
Do you clean the contact-surface`s? Before installing your rim, clean it and the counterpart at the disc/drum.
It makes a diffrence, especially when going fast.I also would suspect the calipers, because the problem remains whether you changed all other parts.( You get new brakepads as you installed the new discs....?) And you installed the correct wheel (Tire-rotation) in the right place??
just what comes to my mind.
PostPosted: Wed Apr 08, 2009 7:41 pm    Post subject: Reply with quote
Thanks Nobbi !!!, i just realised i never cleaned the surfaces and that i have BIG spacers up front. 35mm heavy steel ones...i never tought about it until now...always suspected wear in the bearing housing but that would be much more noticeable.
i'm going to have the spacers removed, disks and tires replaced and pads cleaned and have another try...i doubt that there is anything wrong with the calipers...they just push the pads towards the disk...the disk is only wrapped in one area like in the picture below...so if the calipers would be faulty or the pads would bed in an uneven way there would be wear or wrapage allover the disk.
