Wheel Bearing Oil Seal
isuras2
PostPosted: Fri Jul 31, 2009 7:03 am    Post subject: Wheel Bearing Oil Seal Reply with quote
I have 2 choices for the inner and outer wheel bearing oil seals. They both are fairly identical. One is 62x45x10 while the other is 62x44x8. I am assuming that these are measurements in mm that are ODxIDxW. Which one would I want to use for the inner and outer seals? I would like to use the ones that are 45 ID because they are cheaper, but sometimes cheaper isn't always good. The first are from autohausaz PN 477405641 and the second are National oil seals from Oreilly's.
Thanks,
Rob
'80 931 (sold)
'80 924 NA (sold)
Former Omaha Crew
