return fuel line, need help
masterdave
PostPosted: Tue Aug 04, 2009 2:07 am    Post subject: return fuel line, need help Reply with quote
i have been replacing all the fuel lines on my car except the prime one as that appears to have been replaced right before i got the car. i am on the last line. The return line that comes off the fuel rail and runs underneath the car back to the tank. the line snakes over the rear suspension and the differential. it seems impossible to take out has any one done this orhave any advice on doing it.
88' 924s
thanks
dave
Portporschedon
PostPosted: Wed Aug 05, 2009 2:12 pm    Post subject: Reply with quote
I haven't done it yet, but I've looked at it and I reckon you will need to drop the transmission.
Maybe not completely, but enough for access.
I am sure there is a thread where someone describes cutting an access hole through the rear floor.
Try "search", something will come up.
Don
White 1983 924 - Renovated to near original condition and my daily driver
Dolomite 1986 924S - Coming to the end of a 4 year refurbishment.
Life is not a rehearsal
masterdave
PostPosted: Wed Aug 05, 2009 3:36 pm    Post subject: Reply with quote
i had hoped it would not come to that, the problem seems to be the rear suspension more than any thing the line seems to disappear behind that cross bar the suspension runs over if i can get it over that i can get pull it over the transmission no problem.
PostPosted: Wed Aug 05, 2009 10:25 pm    Post subject: Reply with quote
Can you attach the new line to the old (with a barbed splice fitting, or by slipping a smaller tight-fitting hose inside to hold them together)? Then use the old line to pull the new one into place...
[Scratch that nonsense - I was thinking rubber lines. Of course they're rigid metal..]
ic932
PostPosted: Thu Aug 06, 2009 8:37 am    Post subject: Reply with quote
I use compression fittings to cut out an replace corroded sections. IIRC the olive sizes are 8mm & 10mm. It easily handles the pressure.
masterdave
PostPosted: Thu Aug 06, 2009 3:41 pm    Post subject: Reply with quote
i have already ordered the new line and its on its way, well ive been waiting about a week now, its more getting the line on and of that i was worried about.
ic932
PostPosted: Fri Aug 07, 2009 5:30 am    Post subject: Reply with quote
That's the more sensible option I guess. Lowering the rear suspension beam isn't that bad. Just check that the mounts are worth re-using NOW incase you need to order them.
And while you are in there.....get those bars replaced, 30mm will do!
masterdave
PostPosted: Fri Aug 07, 2009 3:54 pm    Post subject: Reply with quote
ic932 you seem like you have done this before, which bars are you referring too, and which mounts are they rubber or metal, i have a feeling they will need to be replaced as they car was miss treated until i got it, and was the reason of it coming in to my possession in the first place.
masterdave
PostPosted: Fri Aug 07, 2009 4:04 pm    Post subject: Reply with quote
any one with tips on dropping the rear suspension they would be much appreciated, pics are always great.
