fuel lines
944cabby
PostPosted: Wed Jul 22, 2009 3:24 am    Post subject: fuel lines Reply with quote
Could anyone tell me the exact length and diameter of both fuel lines that run from the engine to the rear please?
I want to get some made up locally from hydraulic hose to replace the rusted through ones on mine.
1977 martini 924
1983 met claret 924 lux (sold)
1979 burgundy 924 (broke it for spares)
agfisher
PostPosted: Wed Jul 22, 2009 3:53 am    Post subject: Reply with quote
I'll be interested in what you find out. I'm wondering if I should do the same thing on my Martini.
Adam
1977 924 N/A Martini Edition
PostPosted: Wed Jul 22, 2009 3:59 am    Post subject: Reply with quote
Hmmm. I have two complete sets removed from a couple of long-gone 931 ghost cars. Wonder if they're the same as an NA...will have to check PET.
AG, if they're the same, would you be interested in a set? The ones I have are in pretty darn good shape...but they would probably be a bit of a challenge to ship...
oldmanwintersret
PostPosted: Wed Jul 22, 2009 4:12 am    Post subject: Reply with quote
Mine are being redone at a body shop. Some kind hearted individual took a hack saw to it and spliced in the wrong type of rubber fuel lines. The left door pillar is being redone there, so it is part of the deal. The owner is addicted to Porsches and a wizard with metal!
agfisher
PostPosted: Wed Jul 22, 2009 5:21 am    Post subject: Reply with quote
I might be interested. What is the best way of determining if a fuel line is shot? It's a '77 so maybe that's the answer. It has sat unused for about 20 years or so.
Adam
PostPosted: Wed Jul 22, 2009 7:16 am    Post subject: Reply with quote
Well, ideally, you want to do two things: make sure it ain't blocked, and make sure it don't leak (to put it in the vernacular). The first is easy enough to do by blowing it out with an air compressor and appropriate connector. The second is a bit tougher, but I imagine you could rig up a CIS tester to check for leakdown, and possibly even flow rate.
